Date/Time: Wed, 27 Nov 2024 06:39:31 +0000
Market Depth - Limit Orders
View Count: 262
[2023-09-06 20:43:33]
eharmenteros - Posts: 4
Hello all!
I'm desperately trying to show my DOM in a way where I can see the outstanding limit orders at different price points vis a vis Bookmap.
Could you kindly walk me through the process?
Thanks!
Eric
imageCURRENT SC DOM.jpg / V - Attached On 2023-09-06 20:42:46 UTC - Size: 412.67 KB - 84 views
imageBOOKMAP EXAMPLE.jpg / V - Attached On 2023-09-06 20:42:53 UTC - Size: 320.46 KB - 84 views
[2023-09-07 13:04:18]
John - SC Support - Posts: 36309
With the U.S. Equities you need to have both the "NASDAQ TotalView" and "U.S. Equities Consolidated Tape" exchanges active - which you do.
Then when you enter your symbol, you need to use the suffix of "_MBO". So for SPY, you need to enter the symbol SPY_MBO. This combines the data from the two exchanges so you get all the information from the U.S. Equities Consolidated Tape exchange with the Market Depth from the NASDAQ TotalView exchange.
If you are trading from Sierra Chart for the U.S. Equities, then you will need to set the "Trade and Current Quote Symbol" to what is needed by your trading service. Refer to the information here:
Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu)
