Date/Time: Wed, 27 Nov 2024 06:47:04 +0000
Footprintproblems
View Count: 237
[2023-09-06 18:00:58]
sdeinlein - Posts: 13
Hello I have a problem with my footprint chart in the second line from the top where it says delta %. unfortunately it is no longer displayed correctly but only with a 0 and then a dot 0.14 on the second image where it is correct it is written as 10.7% how can I change this again kind regards simon deinlein
imageFootprint right.png / V - Attached On 2023-09-06 18:00:30 UTC - Size: 604.02 KB - 71 views
imagefootprint wrong.png / V - Attached On 2023-09-06 18:00:37 UTC - Size: 71.37 KB - 67 views
[2023-09-07 12:52:25]
John - SC Support - Posts: 36309
Change the Input for that Numbers Bars study for "Display Percent Values as Decimal or Percentage" to "Percent". Refer to the information for this Input at the following link:
Numbers Bars: Numbers Bars Calculated Values Input Descriptions
Date Time Of Last Edit: 2023-09-07 12:52:49
