Date/Time: Wed, 27 Nov 2024 04:44:38 +0000
Cash balance
View Count: 269
[2023-09-06 14:32:06] |
User344478 - Posts: 144 |
Please reset old cash balance $96.90 to new cash balance $296.90.
[2023-09-06 15:56:11] |
John - SC Support - Posts: 36309 |
We do not understand what you are referring to.
[2023-09-06 16:02:19] |
Sierra_Chart Engineering - Posts: 17190 |
If you are referring to your trading account cash balance, only your broker can do this. Are you referring to the Simulated Futures Trading service? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-17 23:50:14] |
I copy Sierra Chart to another computer. I will use it from now on. I get message from SC. "Failed to open the configuration file when saving. Configuration not saved. Error: Windows error code 5: Access is denied."
[2023-09-18 11:44:07] |
Refer to: Error Messages When Opening Files Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
