Date/Time: Wed, 27 Nov 2024 06:30:25 +0000
Sierrachart V2540 OpenGL
View Count: 455
[2023-09-06 14:02:40] |
Sargon Petros - Posts: 57 |
Hi there, After upgrading to SC V2540 I can no longer use the OpenGL setting. Upon loading any chartbooks, the application quits prematurely. Is anyone else seeing this issue? |
[2023-09-06 15:21:49] |
Sierra_Chart Engineering - Posts: 17190 |
We will put out a new release today and we want to know if it resolves the problem.
[2023-09-07 04:14:58] |
Hi there, Should I update using the "Current Version" or do I need to download a specific release? |
[2023-09-07 14:31:25] |
John - SC Support - Posts: 36309 |
You need to download the "PreRelease" by selecting "Help >> Download PreRelease". Then perform the install from there.
