Date/Time: Wed, 27 Nov 2024 06:26:58 +0000
Account sierra chart
View Count: 292
[2023-09-06 12:23:40]
User227841 - Posts: 2
Bonjour, j'aimerais savoir si j'achète un pack sierra chart aujourd'hui de 1 mois, j'ai jusqu'à fin du mois de septembre ou jusqu'au 6 octobre prochain ??
L'abonnement vaut il 31 jours exactement ?
Cordialement
Emmanuel
[2023-09-06 15:51:09]
John - SC Support - Posts: 36309
From Google Translate:
Hello, I would like to know if I buy a sierra chart pack today of 1 month, I have until the end of September or until the 6th of October next??
Is the subscription worth 31 days exactly?
The Sierra Chart packages work on a rolling 31 day process. So if you purchase a package today, your End Date will be 31 days forward.
Note that the exchanges work differently from this - they work on a Calendar Month basis, where the renewals occur on the first day of each month. The exchanges are also not pro-rated, so if you activate an exchange in the middle of the month, you will pay the full amount for the exchange and you will only get the data through the end of the month - you then have to pay again on the first day of the following month to continue.
