Date/Time: Wed, 27 Nov 2024 08:38:40 +0000
chart time vs. general time zone
View Count: 284
[2023-09-06 05:14:39] |
User61576 - Posts: 444 |
If my SC instance time zone is set for Eastern though my chart time zone is set to Central, I am asking b/c I set to trade the chart at 14:00 only (14:00-14:59) b/c based on the historical activity log I have an edge there (good or bad this is another discussion) but now, although it is set to trade at 14:00, in the activity log, i see the trades on time 15:00-15:59 In the activity log, which time zone is displayed on the "period_stats"--> "hour of day"? so I am asking which of the following should I do? 1. Shift the time set to trade 1 hour back 2. Adjust the chart time from cet. to est thanks |
[2023-09-06 09:28:40] |
Sierra_Chart Engineering - Posts: 17191 |
The time zone of the Trade Activity Log is according to Global Settings >>Time Zone Settings. Whatever you want to do is up to you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-09-06 09:29:05
