Date/Time: Sat, 12 Sep 2026 17:34:30 +0000
[Programming Help] - Problems adding limit orders
View Count: 932
[2023-09-06 01:04:31]
WeroTrader - Posts: 46
Greetings, Sierra Chart team.
I am trying to place two limit orders (one to buy and one to sell) via ACSIL in the same index.
The orders are placed correctly, but they are added, without me having requested it, two additional close orders for each one, one limit type and another stop type; the status of these additional orders is "Pending Child-Client", with zero quantity.
How can I make sure that those additional orders are not placed? This is causing me that when the "correct" order is filled, it is immediately closed.
I am not looking for code, just a correct guide about the instruction that I must follow for the correct handling of limit type orders.
I leave an example of the code for the sales order.
s_SCNewOrder Order_SellGRID;
Order_SellGRID.Symbol = Symbol;
Order_SellGRID.OrderType = SCT_ORDERTYPE_LIMIT;
Order_SellGRID.TimeInForce = SCT_TIF_GOOD_TILL_CANCELED;
Order_SellGRID.OrderQuantity = Batch;
Order_SellGRID.Price1 = GridSell;
Result = static_cast<int>(sc.SellOrder(Order_SellGRID));
I attach images of the orders in the graph, as well as the information that appears in the window of trade orders; thank you in advance for the answer
imageTrade Orders.png / V - Attached On 2023-09-06 01:01:16 UTC - Size: 17.68 KB - 160 views
imageChild - Client.png / V - Attached On 2023-09-06 01:02:38 UTC - Size: 6.54 KB - 163 views
[2023-09-06 07:00:07]
User431178 - Posts: 905
Check out the two items below
ACSIL Interface Members - Variables and Arrays: sc.UseGUIAttachedOrderSetting
ACSIL Interface Members - Variables and Arrays: sc.SupportAttachedOrdersForTrading
[2023-09-06 14:03:23]
The thing is, the orders that appear with status "Pending Child-Client", I didn't attach them and I don't know the reason why they appear.
Is there anything else I can refer to to find the reason?
[2023-09-06 14:19:59]
So both of the above linked items are set to 0 then?
Date Time Of Last Edit: 2023-09-06 14:20:17
[2023-09-07 15:16:37]
Sierra_Chart Engineering - Posts: 24844
Yes set these both to 0 in the sc.SetDefaults code block :
sc.SupportAttachedOrdersForTrading = 0;
sc.UseGUIAttachedOrderSetting = 0;
Date Time Of Last Edit: 2023-09-07 15:17:02
