Date/Time: Wed, 27 Nov 2024 08:46:35 +0000
[User Discussion] - turn off flatten at set time for symbol and account
View Count: 211
[2023-09-05 22:34:46]
User696147 - Posts: 3
The trade window is set to "disabled" under flatten at set time. Under global profit loss the only thing checked is "disable global profit loss on start-up". My position is still getting flattened at 15:14:45 pacific standard time every day. What else should I check? Thank you
[2023-09-06 15:18:01]
John - SC Support - Posts: 36309
Be sure to also check with your broker.
