Date/Time: Wed, 27 Nov 2024 08:37:05 +0000
SC Internal Chat Window File--> Open Chat Window
View Count: 420
[2023-09-05 15:35:10]
skierrick - Posts: 6
I was curious about the internal Chat Window in Sierra Chart and launched the application. A chat window dialog opens and the SC Message Log opens. The messages in the log show it's persistently trying to connect/re-connect to a server. When I dismiss the message log window by clicking the 'X' the window goes away but then instantly presents itself again and again and again.
See attachment for screen shot of the message log. Also pasted portion of message log below
Thank you for your assistance.
Rick
Chat (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-09-05 10:23:47.849 *
Chat (2) | CloseSocket call. | 2023-09-05 10:23:47.849
Lost connection to the server. | 2023-09-05 10:23:47.850
It will reconnect to the server automatically in 2 second. | 2023-09-05 10:23:47.850
Chat (2) | Closed. | 2023-09-05 10:23:47.850
Enable automatic reconnection to the server. | 2023-09-05 10:23:49.850
Chat (0) | CloseSocket call. | 2023-09-05 10:23:49.850
Chat (2) | Creating socket. Using TLS 1.2. | 2023-09-05 10:23:49.859
Chat (2) | New receive buffer size: 0 | 2023-09-05 10:23:49.859
Chat (2) | Connecting to IP: 65.108.77.248. | 2023-09-05 10:23:49.860
Chat (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-09-05 10:23:52.517 *
Chat (2) | CloseSocket call. | 2023-09-05 10:23:52.517
Lost connection to the server. | 2023-09-05 10:23:52.518
It will reconnect to the server automatically in 2 second. | 2023-09-05 10:23:52.518
Chat (2) | Closed. | 2023-09-05 10:23:52.518
Enable automatic reconnection to the server. | 2023-09-05 10:23:54.518
Chat (0) | CloseSocket call. | 2023-09-05 10:23:54.518
Chat (2) | Creating socket. Using TLS 1.2. | 2023-09-05 10:23:54.525
Chat (2) | New receive buffer size: 0 | 2023-09-05 10:23:54.525
Chat (2) | Connecting to IP: 65.108.77.248. | 2023-09-05 10:23:54.525
Chat (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-09-05 10:23:57.168 *
Chat (2) | CloseSocket call. | 2023-09-05 10:23:57.168
Lost connection to the server. | 2023-09-05 10:23:57.168
It will reconnect to the server automatically in 2 second. | 2023-09-05 10:23:57.168
Chat (2) | Closed. | 2023-09-05 10:23:57.168
imageSC_Message_Log_2023-09-05 102231.jpg / V - Attached On 2023-09-05 15:31:46 UTC - Size: 167.56 KB - 102 views
imageSC_Message_Log_2023-09-05 102231.jpg / V - Attached On 2023-09-05 15:32:45 UTC - Size: 167.56 KB - 82 views
[2023-09-05 15:51:12]
Sierra_Chart Engineering - Posts: 17191
You need to update Sierra Chart to the latest version for the up-to-date chat functionality and to support the latest server changes. Otherwise, the connection will not occur.
Update to the latest prerelease 2541:
[2023-09-05 19:49:51]
Thank You - Issue is resolved
