Date/Time: Wed, 27 Nov 2024 08:44:42 +0000
Remove Remove and Cancel Option From Right-Click Menu
View Count: 311
[2023-09-05 15:15:17] |
User128695 - Posts: 10 |
Hey, Is there a way to remove the Remove and Cancel option entirely from the right-click menu? It is way too easy to misclick when close orders, and can seriously mess things up if you're a few pixels off. I know you can disable the option from the Trading DOM, but I can't see how I can remove it from the right-click menu. Thanks |
[2023-09-05 15:47:55] |
Sierra_Chart Engineering - Posts: 17191 |
Global Settings >> Customize Chart Trade Menu. Refer to: Global Settings Menu: Customize Chart Trade Menu (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-09-05 15:49:20
[2023-09-05 15:58:19] |
Thank you so much! You may close the ticket, I've successfully removed it.
