Date/Time: Wed, 27 Nov 2024 08:27:16 +0000
Eurex/Denali/CQG
View Count: 283
[2023-09-05 15:11:10] |
DF52 - Posts: 19 |
I am with Amp and currently using Eurex/Denali with the evaluator. I would like to use Sierra order routing but I see that is not possible for Eurex. Can I trade Eurex with Denali data and order routing via CQG Web API? I can't see documentation for this. Thanks |
[2023-09-05 15:46:33] |
Sierra_Chart Engineering - Posts: 17191 |
Yes: Can I trade Eurex with Denali data and order routing via CQG Web API? Refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
