Date/Time: Wed, 27 Nov 2024 07:32:56 +0000
no MBO data
View Count: 405
[2023-09-05 12:18:42]
User181801 - Posts: 42
Hello and thanks for your help. My MBO column is not populated by data although I am subscribed.
[2023-09-05 15:36:36]
Sierra_Chart Engineering - Posts: 17191
For what particular symbol?
Go through the instructions here:
Market By Order Data: Step-by-Step Instructions
Date Time Of Last Edit: 2023-09-05 15:52:29
[2023-09-06 12:20:10]
It happens in all my DOMs (NQZ23, ESZ23, CLV23, GCZ23).
I follow the instructions including the "update symbol settings" but again no data in mbo columns.
[2023-09-06 13:41:17]
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2023-09-07 13:13:54]
Software version: 2516 64-bit | 2023-09-07 09:09:10.300
Primary Thread ID: 3200 | 2023-09-07 09:09:10.300
Usage end date: 2023-10-02 | 2023-09-07 09:09:10.300
Enabled for: Advanced Features 2. | 2023-09-07 09:09:10.300
Enabled for: Sierra Chart Historical Data Service. | 2023-09-07 09:09:10.300
Enabled for: Denali Real-Time Exchange Data Feed. | 2023-09-07 09:09:10.300
Enabled for: Delayed Denali Exchange Data Feed. | 2023-09-07 09:09:10.300
Enabled for exchange2: CME (Trading Account Required) | 2023-09-07 09:09:10.300
Enabled for exchange2: CBOT (Trading Account Required) | 2023-09-07 09:09:10.300
Enabled for exchange2: COMEX (Trading Account Required) | 2023-09-07 09:09:10.300
Enabled for exchange2: NYMEX (Trading Account Required) | 2023-09-07 09:09:10.300
Enabled for exchange2: fairx_exchange.data | 2023-09-07 09:09:10.300
Allow Support for Sierra Chart Data Feeds is enabled. | 2023-09-07 09:09:10.300
Current selected Data/Trading service: Trading Evaluator | 2023-09-07 09:09:10.300
Custom symbol settings values: enabled | 2023-09-07 09:09:10.300
Chart Update Interval: 500 | 2023-09-07 09:09:10.300
Intraday Data Storage Time Unit: 0 | 2023-09-07 09:09:10.300
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2023-09-07 09:09:10.300
2023-09-07 13:09:10 Local computer time in UTC | 2023-09-07 09:09:10.300
2023-09-07 09:09:10 Local computer time in SC Time Zone | 2023-09-07 09:09:10.300
2023-09-07 13:07:07 Server time in UTC | 2023-09-07 09:09:10.300
Local computer UTC time and Server UTC time difference: 4 seconds. | 2023-09-07 09:09:10.300
Program path: C:\SierraChart\ | 2023-09-07 09:09:10.300
Data Files path: C:\SierraChart\Data\ | 2023-09-07 09:09:10.300
OS Version Number: 10.0 | 2023-09-07 09:09:10.300
Locale Setting: C | 2023-09-07 09:09:10.300
DLLs: UserContributedStudies_64.dll | 2023-09-07 09:09:10.300
Allowed protected custom studies: | 2023-09-07 09:09:10.300
Crash reporter started: true | 2023-09-07 09:09:10.300
Saved Chartbook: test ladder.Cht. Time: 0.0008 seconds. | 2023-09-07 09:09:36.031
Unsubscribed from market depth data for ESU23 | 2023-09-07 09:09:38.458
ESU23 #1 | Reloading chart. | 2023-09-07 09:11:09.469
ESU23 #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-09-07 09:11:09.470
Requesting market depth updates for: ESU23 if supported. | 2023-09-07 09:11:13.518
Denali Data Feed | Clearing market depth for ESU23 | 2023-09-07 09:11:13.787
File >> Disconnect selected. | 2023-09-07 09:11:48.328
Trading Evaluator | Waiting for socket receive thread to end | 2023-09-07 09:11:48.328
DTC Client socket (1) | CloseSocket call. | 2023-09-07 09:11:48.329
DTC Client socket (1) | Max send buffers used during socket life: 4 | 2023-09-07 09:11:48.329
DTC Client socket (1) | Max send buffer size during socket life: 329 | 2023-09-07 09:11:48.329
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-09-07 09:11:48.329
Denali Data Feed | Waiting for socket receive thread to end | 2023-09-07 09:11:48.329
DTC Client socket (3) | CloseSocket call. | 2023-09-07 09:11:48.330
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2023-09-07 09:11:48.330
Denali Data Feed | Disconnected from the server. | 2023-09-07 09:11:48.330
Trading Evaluator | Disconnected. | 2023-09-07 09:11:48.330
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-09-07 09:11:48.480
DTC Client socket (1) | Closed. | 2023-09-07 09:11:48.480
Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 | 2023-09-07 09:12:19.823
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-07 09:12:19.823
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-09-07 09:12:19.824
DTC Client socket (1) | Connecting to IP: 142.215.17.188. | 2023-09-07 09:12:19.824
Trading Evaluator | Network connection to server complete. | 2023-09-07 09:12:19.977
Trading Evaluator | Starting socket receive thread. | 2023-09-07 09:12:19.977
Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2023-09-07 09:12:19.977
Trading Evaluator | Setting DTC encoding to Binary VLS | 2023-09-07 09:12:20.433
Trading Evaluator | Sending logon request message. | 2023-09-07 09:12:20.433
Trading Evaluator | Received logon response. | 2023-09-07 09:12:21.095
Trading Evaluator | Server Name: SC DTC Server. Build=47468. | 2023-09-07 09:12:21.095
Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2023-09-07 09:12:21.095
Trading Evaluator | Successfully connected. Connected to SC DTC Protocol server. Service=tradesimulation.dtctrading|SymbolSettings=tradingevaluatorserver.dtctrading. | 2023-09-07 09:12:21.095
Trading Evaluator | Trading is supported. | 2023-09-07 09:12:21.095
Trading Evaluator | Order cancel and replace is supported. | 2023-09-07 09:12:21.095
Trading Evaluator | OCO Orders supported. | 2023-09-07 09:12:21.095
Trading Evaluator | Bracket Orders supported. | 2023-09-07 09:12:21.095
Trading Evaluator | Connected to server complete. | 2023-09-07 09:12:21.095
Triggering next historical data download in queue. | 2023-09-07 09:12:21.096
Trading Evaluator | Performing query for most recent Order Activity Date-Time. | 2023-09-07 09:12:21.097
No download requests in the queue to start downloads for. | 2023-09-07 09:12:21.097
Mapping ESU23 to ESU23. Service code: cme | 2023-09-07 09:12:21.109
Using symbol data fast lookup vector | 2023-09-07 09:12:21.109
Denali Data Feed | Starting real-time market data updates for: ESU23 (ESU23). ID: 1 Service code: cme | 2023-09-07 09:12:21.109
Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 443 | 2023-09-07 09:12:21.109
Denali Data Feed | Requesting security definition data for: ESU23 (ESU23). ID: 1 | 2023-09-07 09:12:21.109
Added historical Intraday data request for ESU23 to the queue. | 2023-09-07 09:12:21.109
Intraday data recording state for symbol ESU23 is set to download 'Pending'. | 2023-09-07 09:12:21.109
Triggering next historical data download in queue. | 2023-09-07 09:12:21.109
Delaying start of download for ESU23. | 2023-09-07 09:12:21.116
DTC Client socket (2) | Creating socket. | 2023-09-07 09:12:21.121
DTC Client socket (2) | New receive buffer size: 5242880 | 2023-09-07 09:12:21.122
DTC Client socket (2) | Connecting to IP: 142.215.18.148. | 2023-09-07 09:12:21.122
Trading Evaluator | Requesting historical order activity from server. Start date-time UTC: 2023-09-06 16:27:36.467645 | 2023-09-07 09:12:21.144
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESU23 | 2023-09-07 09:12:21.260
Trading Evaluator | Received security definition for symbol ESU23 | 2023-09-07 09:12:21.260
Denali Data Feed | Network connection to server complete. | 2023-09-07 09:12:21.276
Denali Data Feed | Starting socket receive thread. | 2023-09-07 09:12:21.276
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-09-07 09:12:21.277
Trading Evaluator | Received final trade activity snapshot. Count=1. No data. TradeAccount=brvhrt | 2023-09-07 09:12:21.296
Trading Evaluator | Received final trade activity snapshot. Count=1. No data. TradeAccount=dagres | 2023-09-07 09:12:21.373
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-09-07 09:12:21.442
Denali Data Feed | Sending logon request message. | 2023-09-07 09:12:21.442
Denali Data Feed | Received logon response. | 2023-09-07 09:12:22.352
Denali Data Feed | Server Name: SC Realtime Server. | 2023-09-07 09:12:22.352
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-09-07 09:12:22.352
Denali Data Feed | Successfully connected. | 2023-09-07 09:12:22.352
Denali Data Feed | Trading is not supported. | 2023-09-07 09:12:22.352
Denali Data Feed | Restarting real-time data updates for symbol: ESU23 -> ESU23 | 2023-09-07 09:12:22.352
Denali Data Feed | Received security definition for symbol ESU23 | 2023-09-07 09:12:22.605
Requesting market depth updates for: ESU23 if supported. | 2023-09-07 09:12:26.094
Denali Data Feed | Clearing market depth for ESU23 | 2023-09-07 09:12:26.355
HD Request # 8 | Downloading Intraday chart data for ESU23 to the file ESU23.scid. Service: cme | 2023-09-07 09:12:27.661
HD Request # 8 | Download start date-time: 2023-09-07 09:11:43.000000. File last date-time: 2023-09-07 09:11:43.332008 | 2023-09-07 09:12:27.662
HD Request # 8 | Using server: ds28.sierracharts.com port 10150 | 2023-09-07 09:12:27.662
Socket (4) | Creating socket. | 2023-09-07 09:12:27.662
Socket (4) | New receive buffer size: 5242880 | 2023-09-07 09:12:27.662
Socket (4) | Connecting to IP: 142.215.18.147. | 2023-09-07 09:12:27.662
HD Request # 8 | Setting DTC encoding to Binary VLS | 2023-09-07 09:12:27.970
HD Request # 8 | Sending historical data logon request message. | 2023-09-07 09:12:27.970
HD Request # 8 | Requesting Intraday data. Start date-time: 2023-09-07 09:11:43. Record interval: 0. Symbol: ESU23 | 2023-09-07 09:12:28.646
HD Request # 8 | Decompressing data. | 2023-09-07 09:12:28.798
HD Request # 8 | Receiving Intraday data for ESU23 starting at 2023-09-07 09:11:43.332000 | 2023-09-07 09:12:28.950
Socket (4) | CloseSocket call. | 2023-09-07 09:12:28.952
Socket (4) | Shutdown started. Waiting for graceful close. | 2023-09-07 09:12:28.952
Historical data download thread signaled to stop. | 2023-09-07 09:12:28.952
HD Request # 8 | Timestamp of first Intraday data file record written: 2023-09-07 09:11:45.293000. | 2023-09-07 09:12:28.952
HD Request # 8 | Received 481 Intraday data records from 2023-09-07 09:11:43.332000 to 2023-09-07 09:12:24.000000 (40.7 seconds. Delay: 5.0 seconds) and wrote 472 records for ESU23 | 2023-09-07 09:12:28.952
HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2023-09-07 13:12:24.000000 | 2023-09-07 09:12:28.967
HD Request # 8 | Completion time: 1s. | 2023-09-07 09:12:28.968
HD Request # 8 | Intraday data download complete for ESU23. Unique request ID: 8 | 2023-09-07 09:12:28.968
Removing historical data download ID 8. | 2023-09-07 09:12:28.968
Real-time Intraday chart data file updates started for ESU23 | 2023-09-07 09:12:28.968
Intraday chart data file opened for ESU23 | 2023-09-07 09:12:28.968
HD Request # 8 | Enabling Intraday chart updating for symbol. | 2023-09-07 09:12:28.968
Triggering next historical data download in queue. | 2023-09-07 09:12:28.968
No download requests in the queue to start downloads for. | 2023-09-07 09:12:28.968
Socket (4) | Socket gracefully closed by remote side. | 2023-09-07 09:12:29.103
Socket (4) | Closed. | 2023-09-07 09:12:29.103
Opened cached Intraday file: C:\SierraChart\Data\ESU23.scid. Thread ID: 11036 | 2023-09-07 09:12:29.515
[2023-09-07 15:01:48]
John - SC Support - Posts: 36309
Everything in the log looks good. We are not seeing anything showing a problem.
Please give us a screenshot of what you are seeing (or not seeing, as the case may be) by following these instructions:
[2023-09-08 10:00:56]
https://www.sierrachart.com/image.php?Image=1694167125739.png
As you can see my "combined bid ask market orders column", which is the one on the right titled mbo is not populated. For the purpose of making sure I have data, I set the minimum mbo quantity to 10, from the symbol settings.
[2023-09-08 15:16:28]
Is this a sub-instance?
If so, then are you having the same issue in the main instance?
[2023-09-08 15:32:47]
It is a sub-instance, and I am having the same problem in the main instance.
Also I tried openning the main instance only, but again, same result.
[2023-09-08 15:47:07]
We need to start by concentrating only on the Main Instance. Do not do anything in the sub-instances until we have the Main Instance working properly.
To that end, please go through the following instructions and make sure everything is setup properly for the MBO data:
Let us know if you are able to then get the MBO data in the main instance.
[2023-09-08 15:57:02]
the problem is solved. I hadnt applied the server setting in the main instance.
thank you for your time
