Date/Time: Wed, 27 Nov 2024 08:28:53 +0000
Line up 2 symbols each day
View Count: 234
[2023-09-05 10:37:56]
User137942 - Posts: 10
I currently have 2 symbols on the same chart and I want the add symbol to line up with the open price of the main symbol at the start of each day. So the starting point of the 2 symbols are the same each day and it's at the open price of the main symbol. Is it possible to do this?
[2023-09-05 21:56:09]
John - SC Support - Posts: 36309
You would have to calculate the open price difference between the symbols and then multiply (or divide depending on how you did the original ratio) one of the symbols to get them to match up.
Refer to the information for the Arithmetic studies at the following link:
Using the Basic Arithmetic Studies
