Date/Time: Wed, 27 Nov 2024 00:36:20 +0000
HKEX TS TECH for CQG
View Count: 494
[2023-09-05 06:56:32] |
User846000 - Posts: 27 |
Hi, For my CQG connection (yes, apologies in advance for CQG) I cant seem to find HSTECH/HTI index symbol, I've pulled update symbols etc but doesnt pull the symbol if it does exist for CQG. Could you please update the symbol maps, here is the description for HSTECH or HTI: https://www.hkex.com.hk/Market-Data/Futures-and-Options-Prices/Equity-Index/Hang-Seng-TECH-Index-Futures-and-Options?sc_lang=en#&product=HTI Thanks in advance |
[2023-09-07 16:00:12] |
Sierra_Chart Engineering - Posts: 17187 |
We will add this symbol but in the meantime, you can just manually type in the symbol as explained here: File Menu: Find Symbol (File) And open a chart for it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-03 07:29:55] |
This symbol was added. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
