Date/Time: Wed, 27 Nov 2024 08:31:59 +0000
Range chart with different tick size for reversal candle
View Count: 279
[2023-09-04 19:51:59] |
__Kai__ - Posts: 14 |
Dear support team, I’m searching for an option to create a range bar chart with the following two parameters: Tick Trend – is a distance, achieving which a trend candle will be formed and closed. The distance is measured either up or down Tick Reversal – is a distance, achieving which a reversal candle will be formed and closed. A mandatory condition for closing is a back (opposite) price movement in relation to a previous candle The close of the prior candle should be at the same price as the open of the next candle. Is this possible? I couldn’t find a solution yet. Greetings Kai Date Time Of Last Edit: 2023-09-04 19:59:13
[2023-09-05 17:42:03] |
Sierra_Chart Engineering - Posts: 17191 |
Have you looked at Reversal bars?
