Date/Time: Fri, 25 Apr 2025 12:44:37 +0000
Max and Min Ask Vol-Bid Vol Values Number Bars calculated Value Study:
View Count: 644
[2023-09-04 18:09:34]
User88827 - Posts: 2
I have added Maximum Ask Volume Bid Volume Difference and Minimum Ask Volume Bid Volume Difference to the existing Number Bars Calculated Values Study. The rows for the added Max and Min values are coming up all 0 (Zero).
The other rows of the study for Ask Volume Total, Bid Volume Total, Cumulative Volume – Day are populated as expected, why are the Max and Min Ask-Bid Vol rows showing 0 (Zero).
The number bar chart has been recalculated and Sierra chart has been Saved Exited and restarted and all charts & studies operate as expected except for the Min Max rows as mentioned above. Please advise what I missed and or next steps.
https://www.sierrachart.com/image.php?Image=1693850802905.png
[2023-09-05 21:39:52]
John - SC Support - Posts: 39480
There is something a bit odd about the region data line that is displayed for the Numbers Bars Calculated Values study you have. Is this study set to display the data from another chart?
[2023-09-06 00:11:10]
The study is receiving data directly and is not set to receive data from another chart. The chart sent is in its own chartbook with only one other chart with the same Numbers bar study but uses a 1 minute bar period. The 1 Minute chart has the same issues as described in the original post. Yesterday, the 4th was a shorten trading day in the States. Todays data from the 5th, displays the same problem as well.
Private File
[2023-09-06 15:27:09]
You have the "Based On" for the "Numbers Bars Calculated Values" set to "Numbers Bars". You do not want to do this. Set it to be based on the "Main Price Graph" and everything will work properly.
