Date/Time: Wed, 27 Nov 2024 08:34:26 +0000
Issue adding delta to my DOM
View Count: 642
[2023-09-04 17:23:42] |
Kenneth Walker - Posts: 11 |
Hello Can you possibly tell me how I would go about adding delta to my DOM (as in insert) on the right hand side of the price Thank you |
Screenshot (254).png / V - Attached On 2023-09-04 17:23:30 UTC - Size: 221.88 KB - 190 views |
[2023-09-05 15:57:25] |
Sierra_Chart Engineering - Posts: 17191 |
So you mean the difference between ask volume and bid volume at each price level? It can be done left of the price. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-09-05 15:57:36
