Date/Time: Wed, 27 Nov 2024 08:45:00 +0000
Second License Activation
View Count: 373
[2023-09-03 01:50:25]
User519646 - Posts: 15
I activated SC in an other PC (Office). I think you are charging for Denali. Which is fine. I would like to know
1. can I create and use new different log in for my second PC.
2. I wanted to use different trading account .
3. I like to treat that as sub account , That way it cannot see or relate the main license. I will be using different strategies, So I do not want mix up and use wrong account for different strategies.
Please let me know if you need further information. Thanks
[2023-09-03 21:55:03]
Sierra_Chart Engineering - Posts: 17191
Really you should just use a single Sierra Chart account. For both computers. Each installation of Sierra Chart will be separate from each other.
[2023-09-05 21:12:56]
John - SC Support - Posts: 36309
The other thing you need to be aware of is that in order to get the data from our Denali Exchange Data Feed to both computers simultaneously, you will need to set the number of systems for the Denali Exchange Data Feed to 2 and pay for a second set of exchange fees. Refer to the information/instructions at the following link:
Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously
