Date/Time: Wed, 27 Nov 2024 08:48:18 +0000
Study Settings for Multiple Moving Averages - Alerts Conditions
View Count: 260
[2023-09-02 13:42:37] |
User14953 - Posts: 236 |
Do the alert Condition SG Settings need to be assigned so they are accurate to each moving average? My experience has been that the most recent entry is mirrored in the other moving average's alert too. Is this how it is supposed to work or am I doing something wrong? |
[2023-09-02 18:15:21] |
Sierra_Chart Engineering - Posts: 17191 |
This is not clear for us. If you give us the formula you have created and the specific study name it should be referencing, then it will be more clear for us.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-09-02 18:15:33
