Date/Time: Mon, 25 Nov 2024 06:33:44 +0000
How to Disable 'Fast Changing by Keyboard'
View Count: 385
[2023-09-01 19:31:39] |
Tony - Posts: 518 |
Is there a way to disable "Fast Changing by Keyboard", for bar periods and symbols? Thanks |
[2023-09-01 21:32:08] |
You can turn it off for Symbol changes. Refer to the following setting: General Settings Window: Support Symbol Entry from Chart Window (Global Settings >> General Settings >> Charts >> Symbol) But there is not a way to turn off the Bar Period changing option. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-21 15:25:04] |
User656492 - Posts: 143 |
I would really like to disable this method of bar period changing. Often we switch between discord / slack / etc and our charts and I can not tell you how many times I have screwed up my charts and signals in the heat of the moment. PLEASE, allow us to disable this feature! Thanks! |
