Date/Time: Fri, 09 Oct 2026 05:20:39 +0000
Assign shortcut to
View Count: 742
| [2023-09-01 17:37:15] |
| User408639 - Posts: 83 |
Moin Moin. When I tried to assign a keyboard-shortcut to "letters/blocks in own column", I did not find an according google-article (but later I found it under the Market-Profile-synonym TPO). So, I wanted to ask.: 2. Whether we can have the "Global Settings\Customize Keyboard Shortcuts" be made.: a. resizable, b. searchable , i.e.,: i. add a little search-bar showing the found matches in one sub-window, ii. still showing the tree-stucture on the left sid, so, that You can memorize the exact path, that led to the setting. Hopefully, this is not too cheeky to ask for (←too detailed). _Cheers/Tschüß, __Michael. P.S.: Maybe a List/CSV-Export of all keboard-definitions I have been setting is doable. Maybe I can extract it from a settingsfile using the PowerShell, which I can give You for publishing it.: I did find "KeyboardShortcuts4.config" but no lookup-table to the command-name--strings. Date Time Of Last Edit: 2023-09-01 18:03:05
| [2023-09-01 21:04:28] |
| John - SC Support - Posts: 48161 |
We understand what you are asking for, and it is not something that currently exists. Most commands within Sierra Chart have the ability to have a Control Bar and/or a Keyboard Shortcut created for them. Maybe someday we can get around to adding this to the documentation, but it is not something we have the time for at the moment. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
