Date/Time: Wed, 27 Nov 2024 08:46:20 +0000
[User Discussion] - Number Bars (Disable Range 0 Up Color & Range 0 Down Color)
View Count: 385
[2023-09-01 17:36:16]
moe1up - Posts: 22
I've read documentation for Number Bar color variations and don't understand why the Range 0 offers a color no matter what. I read in the instructions to color them the same as the background, but using different background colors as zones makes it a bit challenging. I know that's a personal preference, but if there isn't a way to disable Range 0 from Number Bars, consider this a feature request. Thanks!
[2023-09-01 21:02:25]
John - SC Support - Posts: 36309
We are not 100% certain of what you are wanting to do, but if you do not want to use a Range 0, then set the first two values of the Value Thresholds to be the same. Then set the Range 0 and Range 1 colors to be the same. This will essentially give you 3 range zones instead of 4.
[2023-09-01 22:02:31]
moe1up - Posts: 22
Ultimately, I would like to disable Range 0 values all together. I am not interested in seeing values below my first threshold which is 400%. I've made the first two thresholds to be the same, but that is still populating the non-targeted thresholds below 400%. I keep the value area as a zone on my chart, so when price populates there, the black shows as well. Not a huge problem, but just wanted to bring to attention. Thanks and hagw!
