Date/Time: Wed, 27 Nov 2024 08:42:35 +0000
Alert Condition
View Count: 283
[2023-09-01 17:14:01] |
User585993 - Posts: 83 |
I am creating a formula when the delta is over 5000 and the difference is over 7% on the numbers bar study for both positive and negative delta. so far I have one part of the formula completed, Could you help me with the other part? ABS(ID7.SG1) >0.07*V thanks in advance Date Time Of Last Edit: 2023-09-01 18:27:48
[2023-09-01 20:54:07] |
John - SC Support - Posts: 36309 |
If you are just wanting to check the Delta, then it would be the following: =AND(ABS(ID7.SG1) > 5000, ABS(ID7.SG1) > 0.07 * V) We are assuming that ID7 is the Numbers Bars Calculated Values study where SG1 is the Delta. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
