Date/Time: Wed, 27 Nov 2024 08:35:06 +0000
Real-time data on two computers
View Count: 354
[2023-09-01 16:43:49]
BillsSBC - Posts: 38
Hello, I've enabled the option and paid a second exchange fee to enable two computers to receive real-time data. However, my data is still delayed on the second computer, please advise on what I need to fix or check.
[2023-09-01 20:49:22]
John - SC Support - Posts: 36309
Check the setting for "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds". If this is set to "No", then change it to "Yes", select OK to close the window and then select "File >> Reconnect".
If not the above, then on the system where you are not getting the real-time data follow these instructions to get us your Message Log:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2023-09-01 22:10:21]
This was set to "No" and I'll assume this fixes the problem but can't check until after the weekend. Thank you for the assistance!
