Date/Time: Wed, 27 Nov 2024 08:44:47 +0000
Interactive broker order rejected
View Count: 225
[2023-09-01 14:29:52]
qiw4u23oi4u234 - Posts: 32
ew order rejected - The 'EtradeOnly' order attribute is not supported. Internal Order ID: 175. Service Order ID: 107. Symbol: CL-202310-NYMEX. Account: U2585691 | 2023-09-01 14:24:50.751 *
I tried both TWS Latest (10.24.1f) and the stable version (10.19.2d).
I get the same error using IB's data and using Denali data.
Sierrachart is also updated to the latest but did not fix the error.
Please help.
[2023-09-01 15:06:48]
John - SC Support - Posts: 36309
Make sure you are on the latest Stable version of TWS and the latest version of Sierra Chart.
If that does not resolve it, then you would need to check with Interactive Brokers to start and get more information from them on the error.
