Date/Time: Wed, 27 Nov 2024 08:30:38 +0000
[User Discussion] - How fast is the NYSE/NASDAQ real time data?
View Count: 323
[2023-09-01 14:24:24]
User332190 - Posts: 2
Hello Sierra Charts:
How fast is your NYSE/NASDAQ real time data? seconds, milliseconds, microseconds? What is the latency to the exchanges?
Thanks,
Duane
[2023-09-01 15:05:25]
John - SC Support - Posts: 36309
The data is is per trade and is tagged to the millisecond.
Latency varies depending on your location, so we can't really answer this directly.
[2023-09-01 16:37:09]
Sierra_Chart Engineering - Posts: 17191
This is a very low latency data feed. Data is obtained direct from CTA and UTP.
Latency would range anywhere from about 1 to 20 ms.
Date Time Of Last Edit: 2023-09-01 16:38:09
[2023-09-01 16:48:08]
So we get price-action updates every millisecond? Is this FIX data?
[2023-09-02 00:32:53]
It depends how often the trading is. It is not every millisecond. The trading is constantly variable.
No it is not FIX data. The exchanges do not deliver data that way. It is binary encoded data.
For active symbols like SPY, you will see a continuous flow of data.
Date Time Of Last Edit: 2023-09-02 00:33:19
