Date/Time: Wed, 27 Nov 2024 06:26:58 +0000
Build With Visual C++ - output file permission
View Count: 295
[2023-09-01 13:36:07]
tothemoon - Posts: 2
Hello there, just tried to use the VS for study development based on your tutorial here. If I try the Build Visual C++ - Debug , it runs into error:
- : fatal error C1083: Cannot open compiler generated file: 'C:\Windows\MaxOpenClose.obj': Permission denied
Why does it try to use Windows dir? Is there any way I can change the output folder path?
Thanks in advance
[2023-09-07 17:31:27]
It solved. The problem was because I run with Parallers on Mac and there was some difficulty with the file paths. Win cmd script does not handle the mac style paths.
