Date/Time: Wed, 27 Nov 2024 08:42:04 +0000
TPO Value Lines not matching.
View Count: 308
[2023-09-01 04:40:08] |
User135370 - Posts: 162 |
Hi I have attached the image which should help I have added the TPO Value Lines study and want to have the transparent fill top and bottom which I know how to do The lines are not matching the TPO or even the volume profile Any ideas what I'm doing wrong |
TPO not matching .png / V - Attached On 2023-09-01 04:38:45 UTC - Size: 79.65 KB - 76 views |
[2023-09-01 04:56:58] |
James A Adams - Posts: 13 |
Hi
I have attached the image which should help I have added the TPO Value Lines study and want to have the transparent fill top and bottom which I know how to do The lines are not matching the TPO or even the volume profile Any ideas what I'm doing wrong Make sure TPO tick setting is either set to 1 as well, or change the tpo value lines tick setting to 2 which is what the TPO is set to if applied and not changed. Also in TPO settings, make sure value area is NOT set to calculate value area from volume. Also make sure new period at start of new session is checked on both. |
[2023-09-01 06:19:44] |
The TPO Value Area Lines study can only be used on a standard chart and not a TPO Profile Chart. If of this study is used on a TPO Profile Chart the calculations will be inaccurate. Found the reason in the documentation. Seems you cannot use them on the TPO. Date Time Of Last Edit: 2023-09-01 13:04:31
[2023-09-01 14:29:19] |
John - SC Support - Posts: 36309 |
The last statement is correct.
