Date/Time: Wed, 27 Nov 2024 00:27:17 +0000
Zig Zag Study
View Count: 1064
[2014-07-14 13:10:35] |
User025429 - Posts: 26 |
Thank you for adding the new re-start at the beginning of each day feature. Should this starting point not be the open of each day - currently it uses the previous high/low?
[2014-07-14 15:45:12] |
Yes. It does make sense that it will use the High and Low of the new bar for the day.
