Date/Time: Wed, 27 Nov 2024 08:48:22 +0000
Rithmic vs SC data discrepency
View Count: 342
[2023-09-01 00:59:25] |
User785723 - Posts: 57 |
I am using 10 tick range bars for ES with the attached chart settings. When current selected service is "Rithimic Direct - DTC [trading]", the begin and end time of range bar candles and hence the OHLC values are different from when it's selected to be "SC Data - All Services [data]". What can be the reason? |
Chart settings.jpg / V - Attached On 2023-09-01 00:58:45 UTC - Size: 121.37 KB - 92 views |
[2023-09-01 12:42:45] |
Sierra_Chart Engineering - Posts: 17191 |
Refer to the information here: Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
