Date/Time: Wed, 27 Nov 2024 08:40:04 +0000
[User Discussion] - Brokers that support trading stocks with Sierra Chart
View Count: 581
[2023-08-30 14:43:41]
User584005 - Posts: 27
Interactive brokers requires IBKR Pro to access using Sierra Chart and its costing too much per share to be a viable solution. Is there a free broker I can connect to Sierra Chart?
[2023-08-30 15:50:24]
John - SC Support - Posts: 36309
There is no such thing as a "Free" broker.
But, if you are only trading the CME Group, then we recommend using our Teton Order Routing Service, as we do not charge any order routing fees, which can save you about $0.10 per side for trades. You will find the list of supported brokers at Step #2 of the Setup Instructions at the following link:
Sierra Chart Teton Futures Order Routing: Setup Instructions
We have also set this as a "User Discussion" post so others can give you thoughts on a broker.
