Date/Time: Wed, 27 Nov 2024 08:35:54 +0000
Custom weekly bars.
View Count: 222
[2023-08-30 14:10:32]
Wesplpl - Posts: 7
HI.
Can I set custom weekly bars?
For example Wednesday-Tuesday.
[2023-08-30 15:47:08]
John - SC Support - Posts: 36309
You would have to do this using Intraday Data and set the number of days to 7. Then make sure that the data you load into the chart starts on a Wednesday - this is done most easily by using the "Chart >> Chart Settings >> Data Limiting >> Date Range From/To". Refer to the following:
Chart Settings: Weekly Bars (Time Specific Bars)
