Date/Time: Wed, 27 Nov 2024 08:46:39 +0000
formula time
View Count: 310
[2023-08-30 12:03:48]
User278398 - Posts: 291
hello,
what is the formula that will work only between 30-50 sec?
(i have spreadsheet study (in 1 sec chart) with equation that i built.
i want that equation will work only when the second time is between 30-50 second.
for exa: the equation will work at 9:30:30-9:30:50 and at 9:31:30-9:31:50 and.......)
regards.
[2023-08-30 15:12:59]
John - SC Support - Posts: 36309
Within a Spreadsheet Study you would use the following formula to get the seconds as a single value based on the current time:
=INT(FRACTIME(FRACTIME(FRACTIME(NOW()) * 24) * 60) * 60)
Make sure your computer clock is synced with the data, as the above gives the time from your computer clock.
[2023-09-03 15:17:20]
i understand the formula u wrote, but it is not what i wish for.
i will be more specific:
i have id1: spreadsheet formula study, and the formula i have in it:
=1
also,
i have id2: spreadsheet formula study, and the formula i have in it:
=if(XXX,ID1.SG1,0)
i want to get ID1.SG1, between 30-50 sec in every min.
how "=INT(FRACTIME(FRACTIME(FRACTIME(NOW()) * 24) * 60) * 60)" can give me what i need !?
can u help me with the specific formula (replace to "xxx") to get what i need?
many thanks.
[2023-09-03 15:43:19]
Sawtooth - Posts: 4120
Try this:
=AND(SECOND(BARTIME)>30,SECOND(BARTIME)<50)
[2023-09-04 08:31:09]
amazingggg, thank youuuuuu
