Date/Time: Tue, 26 Nov 2024 10:45:16 +0000
WTI CL 321 Crack spread,custom symbol creation
View Count: 1079
[2023-09-08 16:23:40] |
User720879 - Posts: 28 |
Hi John This is very messy, It's clear that SC needs a solution to spread charting, If you look at something like TOS they have a simple spreader, TT has easy solution, just type in the formula and you get the chart? I have spent some time on this and the attached chart is the simplest method I have managed to achieve, I would appreciate you checking it, it seems to work! Are there any plans to simplify this? Kind regards Steve |
Crack spread 321r1.Cht - Attached On 2023-09-08 16:22:40 UTC - Size: 12.88 KB - 195 views |
[2023-09-08 17:33:17] |
John - SC Support - Posts: 36286 |
The simplified method is the "Custom Calculated Symbols", but this whole thing started since you did not like having to redo the formula for each new contract.
[2023-09-08 17:51:54] |
I appreciate that but its very limited, that method would be better if there was a continuous symbol code like CL# Thank you for your help, don't get me wrong, I love SC and I'm only trying to provide constructive feedback, I know many traders that share these frustrations. |
[2023-12-05 04:22:38] |
DayTraderEsad - Posts: 121 |
I'm a spread trader and reading this forum on the 321 crack spread....what I can do is very simple. I can write a study where you just input the contracts to have auto-roll attached and a easy to way to create any type of spreads. Just got the idea by reading all the issues folks are having. Another thing I am working on for myself is a spread matrix, which is in progress. |
