Date/Time: Wed, 27 Nov 2024 08:38:52 +0000
Historical Volume Bars Over-Riding Manual Input
View Count: 210
[2023-08-29 20:31:55] |
TraderBiku - Posts: 36 |
Hello, I'm trying load a 500 Volume bars on my NQ chart and when I enter "500" under the Volume Per Bar setting, the chart momentarily loads 500Vol bars and then immediately re-downloads and re-sets to 1000Vol bars - I also see the number re-set within the Chart settings dialogue. Is there some minimum level of volume per bar that can be loaded for volume bars? If not, what might be the cause of this? Thank you - |
[2023-08-29 20:52:47] |
John - SC Support - Posts: 36309 |
Refer to the following: Unable to Change the Bar Time Period for Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
