Date/Time: Wed, 27 Nov 2024 08:39:15 +0000
Can't download depth for any 6S CME contracts
View Count: 735
[2023-08-29 20:10:46] |
Flo_O - Posts: 4 |
Hello, downloading any other CME futures depth works all fine but Im not able to download any historical depth for 6S CME contracts like 6SU23_FUT_CME or 6SM23_FUT_CME. I can record a live record which gets stored in a .depth file like it should and is visible on chart but the menu tool 'Download Depth Data from Date-Time' just has no effect here. Also no log in the Message Log window is created. I have no clue anymore what to do best regards |
[2023-08-30 00:41:09] |
Sierra_Chart Engineering - Posts: 17191 |
We will make sure historical market depth data is available for this symbol.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-08-30 14:13:41
[2023-08-30 15:44:00] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-30 15:54:36] |
Flo_O - Posts: 4 |
AWESOME IT WORKS NOW!! Thank you so much!! :)
