Date/Time: Wed, 27 Nov 2024 08:38:53 +0000
Point and Figure chart w/ Large Volume Trade Indicator...
View Count: 329
[2023-08-29 16:23:21] |
User629089 - Posts: 93 |
Hi, I'm trying to create a Point and Figure chart that includes the Large Vol Trade Indicator. I'd like this to show the identical volume that appears on my Footprint chart. I've got it to work but the P&F doesn't show all the 100 lot plus volume that the FP does. The Large Volume Trade Indicator that has been added to the P&F chart is identical to the FP study with the exception of positioning and sizing. Please check the attached images where you'll see only a couple 100 lots registering on the P&F with many more on the FP. Any idea's on this? https://www.sierrachart.com/image.php?Image=1693324806579.png https://www.sierrachart.com/image.php?Image=1693324969803.png Please check out the ellipses on each chart... Maybe it's somehow filtering the volume or? Thanks... |
[2023-08-29 17:14:41] |
John - SC Support - Posts: 36309 |
Please get us those two charts in a Chartbook and attach the chartbook to this thread. There are too many possible items to go over, so we will take a look and see what is different. Follow these instructions to attach a chartbook: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-08-29 17:15:28
[2023-08-29 20:00:19] |
Hi, I've created a new chartbook and Uploaded the file named "Chartbook1.Cht" @ 184.83 KB but I'm not seeing it attached here. Shouldn't it show here somewhere as an attachment? I think I've followed the instructions properly so I'm not sure what is up... Thanks |
Private File |
[2023-08-29 20:45:36] |
There is a setting for "Chart >> Chart Settings >> Chart Data >> Combine Trades into Original Summary Trade". This is set differently for the two charts. Once you make them the same the results for the Large Volume Trade Indicator will be the same. Refer to the following: Chart Settings: Combine Trades into Original Summary Trade (Data Feed and Exchange Specific) (Chart >> Chart Settings >> Chart Data >> Chart Data menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
