Date/Time: Wed, 27 Nov 2024 08:38:18 +0000
Line until intersection
View Count: 280
[2023-08-28 14:12:27]
User135370 - Posts: 162
Hi I have a study overlay of the swing high/low on the indicator pane, I have set it to point below and above bar there, is there a way to get it to draw a line until future intersection?
Image attached, does this have to be coded?
imageUntil intersection .png / V - Attached On 2023-08-28 14:11:56 UTC - Size: 20.24 KB - 78 views
[2023-08-28 17:02:15]
John - SC Support - Posts: 36309
You would have to enable the Input for "Extend Swings until Future Intersection" on the Swing High/Low study first, then on the "Study/Price Overlay" there is an Input for "Copy Extension Lines from Source Study" which would have to be set to "Yes".
[2023-08-28 17:07:40]
Thanks John
