Date/Time: Wed, 27 Nov 2024 08:49:19 +0000
Denali update interval/remote buffer questions
View Count: 284
[2023-08-28 13:12:48] |
User690628 - Posts: 8 |
Hi, I have a very fast CPU, lots of RAM, and a fast internet connection, so I aim to optimize the Denali update interval and buffer as much as possible. I understand this is at my own risk, but I do have a couple of questions: 1) What is the default remote buffer setting for Denali if I select 0? 2) Is it best to match the buffer to the update interval 1:1? So, if I wish to use 10ms update interval, should I set the buffer to 10ms? If not, what is the optimal ratio of buffer to update interval? 3) Does the remote buffer accept the 10ms value, or what is the lowest? I read somewhere in the board that 20ms might be the lowest option available? Thank you |
[2023-08-29 00:44:14] |
Sierra_Chart Engineering - Posts: 17191 |
1. 80 ms. 2. Yes you can match the two of them that will be fine. But the minimum is 20 ms. 3.Lowest is 20 ms. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
