Date/Time: Wed, 27 Nov 2024 03:53:17 +0000
My live trade dissapears
View Count: 456
[2023-08-28 13:03:11]
User761234 - Posts: 21
I had no issues with Sierra for the first month. Today I start trading and I see how my live trades dissapears after a few seconds. My orders are still there but as soon as I'm in, I can't see it. I didn't make any changes at all just a new day. please help
[2023-08-28 15:29:34]
Sierra_Chart Engineering - Posts: 17190
This can be a problem when using Interactive Brokers.
See if updating Sierra Chart resolve the problem. Instructions:
Date Time Of Last Edit: 2023-08-28 15:29:49
[2023-08-30 13:06:49]
I tried installing all versions from your link but still having the same issues
[2023-08-30 15:33:48]
John - SC Support - Posts: 36309
Refer to the following regarding this kind of issue with Interactive Brokers:
Interactive Brokers Trading Service: Trading Related Issues
[2023-09-01 13:07:31]
I see. Could you please send me a link with all accepted brokers and if you have your favorites (software wise). I'd like to find a broker that fits well with Sierra
[2023-09-01 13:22:37]
We need to know what exchanges you are trading.
[2023-09-02 00:49:48]
I usually trade CME. Mostly Micro e-mini S&P500
[2023-09-05 20:34:51]
Since you are trading the CME group, we recommend using our Teton Order Routing service. Refer to the information for this service at the following:
A list of brokers that support this service is in Step #2 of the Setup Instructions on that page.
[2023-09-06 18:58:57]
ok, I see the service is free to use Is there any monthly fee? and other than the setup is there anything else I have to do to get it?
[2023-09-07 12:57:45]
Keep in mind when we say it is free - that is our part of the order routing that is free (you will still pay the typical fees to the broker). Typically order routing fees run $0.08 to $0.15 per side. There are no other fees from us, particularly since you are already getting your data from us.
In terms of setup, the first thing is to tell the broker that you are working with to set you up with the Teton Order Routing Service. They will need your Sierra Chart Account Name to do the setup. Once they have this complete, then you will go through the Setup Instructions at the following link starting at Step #6:
Sierra Chart Teton Futures Order Routing: Setup Instructions
[2023-09-22 12:28:48]
Hey guys! I moved my trading to Phillip Capital (through Edge Water). Trying to use it but something is not right. When I open a chart through Teton, there is no Data coming in and there is no [M] even if on IB there is the [M]. Is there anything else I still need to do?
[2023-09-22 12:49:29]
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2023-09-22 13:11:56]
Software version: 2541 64-bit | 2023-09-22 08:09:11.421
Primary Thread ID: 11476 | 2023-09-22 08:09:11.421
Usage end date: 2024-02-23 | 2023-09-22 08:09:11.421
Enabled for: Advanced Features 2. | 2023-09-22 08:09:11.421
Enabled for: Sierra Chart Historical Data Service. | 2023-09-22 08:09:11.421
Enabled for: Denali Real-Time Exchange Data Feed. | 2023-09-22 08:09:11.421
Enabled for: Delayed Denali Exchange Data Feed. | 2023-09-22 08:09:11.421
Enabled for exchange2: CME | 2023-09-22 08:09:11.421
Enabled for exchange2: fairx_exchange.data | 2023-09-22 08:09:11.421
Allow Support for Sierra Chart Data Feeds is enabled. | 2023-09-22 08:09:11.421
Current selected Data/Trading service: Teton CME Order Routing | 2023-09-22 08:09:11.421
Custom symbol settings values: enabled | 2023-09-22 08:09:11.421
Chart Update Interval: 500 | 2023-09-22 08:09:11.421
Intraday Data Storage Time Unit: 0 | 2023-09-22 08:09:11.421
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2023-09-22 08:09:11.421
2023-09-22 13:09:11 Local computer time in UTC | 2023-09-22 08:09:11.421
2023-09-22 08:09:11 Local computer time in SC Time Zone | 2023-09-22 08:09:11.421
2023-09-22 00:04:32 Server time in UTC | 2023-09-22 08:09:11.421
Local computer UTC time and Server UTC time difference: 1 seconds. | 2023-09-22 08:09:11.421
Program path: C:\SierraChart\ | 2023-09-22 08:09:11.421
Data Files path: C:\SierraChart\Data\ | 2023-09-22 08:09:11.421
OS Version Number: 10.0 | 2023-09-22 08:09:11.421
Locale Setting: C | 2023-09-22 08:09:11.421
DLLs: UserContributedStudies_64.dll | 2023-09-22 08:09:11.422
Allowed protected custom studies: | 2023-09-22 08:09:11.422
Crash reporter started: true | 2023-09-22 08:09:11.422
MES-202312-CME-USD 1 Min #1 | Reloading chart. | 2023-09-22 08:09:25.646
File >> Disconnect selected. | 2023-09-22 08:09:46.090
Teton CME Order Routing | Waiting for socket receive thread to end | 2023-09-22 08:09:46.090
DTC Client socket (1) | CloseSocket call. | 2023-09-22 08:09:46.091
DTC Client socket (1) | Max send buffers used during socket life: 3 | 2023-09-22 08:09:46.091
DTC Client socket (1) | Max send buffer size during socket life: 329 | 2023-09-22 08:09:46.091
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-09-22 08:09:46.091
Teton CME Order Routing | Disconnected. | 2023-09-22 08:09:46.092
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-09-22 08:09:46.149
DTC Client socket (1) | Closed. | 2023-09-22 08:09:46.149
Teton CME Order Routing | Firm: Phillip Capital | 2023-09-22 08:09:55.475
Teton CME Order Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11088 | 2023-09-22 08:09:55.475
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-22 08:09:55.485
DTC Client socket (1) | New receive buffer size: 0 | 2023-09-22 08:09:55.486
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2023-09-22 08:09:55.486
Teton CME Order Routing | Network connection to server complete. | 2023-09-22 08:09:55.539
Teton CME Order Routing | Starting socket receive thread. | 2023-09-22 08:09:55.539
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2023-09-22 08:09:55.539
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-09-22 08:09:55.708
Teton CME Order Routing | Sending logon request message. | 2023-09-22 08:09:55.708
Teton CME Order Routing | Received logon response. | 2023-09-22 08:09:56.231
Teton CME Order Routing | Server Name: SC DTC Server. Build=46374. | 2023-09-22 08:09:56.231
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2023-09-22 08:09:56.231
Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2023-09-22 08:09:56.231
Teton CME Order Routing | Trading is supported. | 2023-09-22 08:09:56.231
Teton CME Order Routing | Order cancel and replace is supported. | 2023-09-22 08:09:56.231
Teton CME Order Routing | OCO Orders supported. | 2023-09-22 08:09:56.231
Teton CME Order Routing | Bracket Orders supported. | 2023-09-22 08:09:56.231
Teton CME Order Routing | Connected to server complete. | 2023-09-22 08:09:56.231
Triggering next historical data download in queue. | 2023-09-22 08:09:56.234
Subscribing to symbol for symbol alert. M6E-202309-CME | Number times prior message previously added: 3 | 2023-09-22 08:09:56.234
Using symbol data fast lookup vector | 2023-09-22 08:09:56.235
Teton CME Order Routing | Starting real-time market data updates for: M6E-202309-CME. ID: 1 | 2023-09-22 08:09:56.235
Teton CME Order Routing | Subscribing to streaming market data in the service client is not supported. Symbol: M6E-202309-CME | 2023-09-22 08:09:56.235
Teton CME Order Routing | Requesting security definition data for: M6E-202309-CME. ID: 1 | 2023-09-22 08:09:56.235
Updated verified funded futures trading account ending date to: 2023-10-22 13:09:56 | 2023-09-22 08:09:56.235
Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2023-09-22 08:09:56.235
No download requests in the queue to start downloads for. | 2023-09-22 08:09:56.235
Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2023-09-22 13:06:02.072930 | Number times prior message previously added: 3 | 2023-09-22 08:09:56.239
Teton CME Order Routing | Starting real-time market data updates for: MES-202312-CME-USD. ID: 2 | 2023-09-22 08:09:56.258
Teton CME Order Routing | Subscribing to streaming market data in the service client is not supported. Symbol: MES-202312-CME-USD | 2023-09-22 08:09:56.258
Teton CME Order Routing | Requesting security definition data for: MES-202312-CME-USD. ID: 2 | 2023-09-22 08:09:56.258
No historical data client is currently set to download historical Intraday data for MES-202312-CME-USD. | 2023-09-22 08:09:56.258
Real-time Intraday chart data file updates started for MES-202312-CME-USD | 2023-09-22 08:09:56.258
Intraday chart data file opened for MES-202312-CME-USD | 2023-09-22 08:09:56.258
Teton CME Order Routing | Security Definition request has been rejected. Reason: Unsupported symbol.. ID = 1 | 2023-09-22 08:09:56.288
Updated verified funded futures trading account ending date to: 2023-10-22 13:09:56 | 2023-09-22 08:09:56.288
Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=7PV3325 | 2023-09-22 08:09:56.296
Teton CME Order Routing | Security Definition request has been rejected. Reason: Unsupported symbol.. ID = 2 | 2023-09-22 08:09:56.337
[2023-09-22 13:17:32]
This is not the correct symbol:
MES-202312-CME-USD
You need to translate the symbols with this Edit menu command:
Edit Menu: Edit >> Translate Symbols To Current Service
[2023-09-22 13:31:21]
the translate button doesn't do anything. I had to rebuild each chartbook 1 by 1. That's probably the same issue with IB.
