Date/Time: Wed, 27 Nov 2024 08:34:18 +0000
APEX BEUG
View Count: 276
[2023-08-28 12:33:47] |
User505585 - Posts: 2 |
Hello it is impossible for me to use a prop firm with Sierra . I am at Apex, it connects and it is impossible to have the history up to date or even to place an order. How to do it ?
[2023-08-28 15:36:00] |
Sierra_Chart Engineering - Posts: 17191 |
The problem is you are getting data from Rithmic and there are known issues with Rithmic historical data. The reason you are not able to access the Denali Data Feed and CME data which you have active is for this reason: The reason you are not getting real-time data from the Denali Data Feed, and historical data from the Denali Data Feed in the case of when using an external Trading service (Rithmic, CQG, Interactive Brokers), from the CME Group of exchanges is that you activated the *Non-Professional* exchange fees. However, you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees. Refer to the "Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges" section here: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Rithmic paper trading or trading evaluator accounts are not considered a live funded futures trading account. Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you do not have a funded trading account or one with a supported Trading service, then refer to this solution: Easy Solution to CME Funded Trading Account Requirement Consider the above solution to avoid this problem in the future. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-29 18:36:05] |
j4ytr4der_ - Posts: 938 |
Don't use Rithmic for market data. You are asking for trouble. Use the Denali data feed. Rithmic will only handle your executions to Apex. I trade 3 funded accounts at Apex as well as other companies, and Denali is the way to go without question.
