Date/Time: Wed, 27 Nov 2024 08:49:04 +0000
Calculation issues
View Count: 227
[2023-08-27 23:07:35] |
doctor10 - Posts: 78 |
Why would two computers with the same chart file and same depth data set calculate depth data differently?
[2023-08-28 00:50:18] |
Sierra_Chart Engineering - Posts: 17191 |
What specific calculation are you referring to? We are not sure. The basic market depth data does not involve any calculations. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-28 00:58:51] |
I analyze depth by level then run basic arithmetic study’s to pull information out. Could incorrect time settings cause two systems to render completely different results?
[2023-08-28 04:11:15] |
It may have something to do with the time zone setting. You need to look at the actual underlying market depth values and see if there any differences. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
