Date/Time: Wed, 27 Nov 2024 06:38:48 +0000
studies showing different stats on the same symbol between different charts on the same
View Count: 301
[2023-08-27 23:01:18] |
Shlomi.B - Posts: 42 |
I have an issue I cant seem to resolve myself. Please help. on the same chartbook, on the same symbol I have the vawap and moving averages showing different prices between different charts for example, on my 5 min footprint my daily session vwap is showing 4423.10 and on my 10 tick ranko chart the daily session vwap is 4421.25. why is it not the same? the study has the same settings between both charts and the chart settings are the expect same other then the way i view the data of course, ie time zone, session time and such. another example is my 50 and 200 moving averages, on the ranko chart the 50ma is 4410.88 and the 200ma 4399.29 but on my 5 min foot print chart the 50ma is 4417.55 and the 200ma is 4400 im having the same problem with 30 min initial balance between these two charts. how can I fix that so I have all my studies showing the same stats between all my charts. thank you. |
[2023-08-28 00:35:20] |
Sierra_Chart Engineering - Posts: 17190 |
You are not going to get a match. The exact starting and ending times of the bars and the number of bars being used in the calculations are going to vary among these charts. You simply are never going to get a match. It is not possible. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-08-28 00:36:07
[2023-08-28 02:06:27] |
Thank you for responding, is there a way to have a study on one chart showing its stats on another chart like in the option of having "copy chart drawing" but without having a study configured on each chart? if having a study on each chart is showing different stats if ill only have it on one chart but will populate on my other charts they will all show the same stats. is that possible? |
[2023-08-28 16:15:14] |
John - SC Support - Posts: 36309 |
Refer to the following: Study/Price Overlay Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-07 03:59:46] |
ABSOLUTELY AMAZING!!! thank you so much for your help. this solved my problem.
