Date/Time: Wed, 27 Nov 2024 04:42:28 +0000
Interactive Brokers / Sierra Chart Message - IB preventing connection????
View Count: 526
[2023-08-27 14:50:27]
User101871 - Posts: 9
Hello all,
I get this error message on a sunday! Is this message valid or because on Sunday markets are close?
What is this all about with interactive brokers?
https://ibb.co/xXq8LtL
https://ibb.co/hdtHnVx
https://ibb.co/bzYJTQF
https://ibb.co/VxWnLg6
Cat
imageerrorSC.jpg / V - Attached On 2023-08-27 14:43:23 UTC - Size: 234.41 KB - 90 views
[2023-08-27 20:39:17]
Sierra_Chart Engineering - Posts: 17190
Go through the steps here to resolve connection problems to Interactive Brokers:
https://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#IBResolvingConnectionIssue
[2023-08-28 12:46:28]
Thank you very much for sharing this link, I read it and try to fix it but it is still not working.
Is this a message board where Sierra Chart users are also reading?
Maybe someone had the same issue and might be able to help
[2023-08-28 15:36:37]
Connect to the data feed:
Select "File >> Disconnect"
Select "File >> Connect to Data Feed"
[2023-08-30 11:46:40]
will do today
[2023-09-04 18:07:25]
Reading Internal Order ID file. | 2023-09-04 13:56:20.154
Reading Trade Orders file. | 2023-09-04 13:56:20.214
Reading Trade Positions file. | 2023-09-04 13:56:20.218
Reading Trade Account Data files. | 2023-09-04 13:56:20.221
Software version: 2528 64-bit | 2023-09-04 13:56:20.224
Primary Thread ID: 11488 | 2023-09-04 13:56:20.224
Usage end date: 2024-02-27 | 2023-09-04 13:56:20.224
Enabled for: Advanced Features 2. | 2023-09-04 13:56:20.224
Enabled for: Sierra Chart Historical Data Service. | 2023-09-04 13:56:20.224
Enabled for: Denali Real-Time Exchange Data Feed. | 2023-09-04 13:56:20.224
Enabled for: Delayed Denali Exchange Data Feed. | 2023-09-04 13:56:20.224
Enabled for exchange2: fairx_exchange.data | 2023-09-04 13:56:20.224
Allow Support for Sierra Chart Data Feeds is enabled. | 2023-09-04 13:56:20.224
Current selected Data/Trading service: Interactive Brokers | 2023-09-04 13:56:20.224
Custom symbol settings values: enabled | 2023-09-04 13:56:20.224
Chart Update Interval: 500 | 2023-09-04 13:56:20.224
Intraday Data Storage Time Unit: 0 | 2023-09-04 13:56:20.224
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2023-09-04 13:56:20.224
2023-09-04 17:56:20 Local computer time in UTC | 2023-09-04 13:56:20.224
2023-09-04 13:56:20 Local computer time in SC Time Zone | 2023-09-04 13:56:20.224
2023-09-04 17:56:34 Server time in UTC | 2023-09-04 13:56:20.224
Local computer UTC time and Server UTC time difference: 15 seconds. | 2023-09-04 13:56:20.224
Notice: Your computer's clock is off by 15 seconds. For help with this, press the 'Send for Analysis' button. | 2023-09-04 13:56:20.224
Program path: C:\SierraChart\ | 2023-09-04 13:56:20.224
Data Files path: C:\SierraChart\Data\ | 2023-09-04 13:56:20.224
OS Version Number: 10.0 | 2023-09-04 13:56:20.224
Locale Setting: C | 2023-09-04 13:56:20.224
DLLs: TWFX_FREE_64.dll, TWFX_FREE_SWS_64.dll, TWFX_FREE_ZZS_64.dll, UserContributedStudies_64.dll | 2023-09-04 13:56:20.226
Allowed protected custom studies: TWFX_Free | 2023-09-04 13:56:20.226
Crash reporter started: true | 2023-09-04 13:56:20.226
Checking for new symbol settings. Requested symbol settings MD5 for service code interactive_brokers.trading. Request ID: 1. | 2023-09-04 13:56:20.245
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2023-09-04 13:56:20.301
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2023-09-04 13:56:20.337
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2023-09-04 13:56:20.337
Received 5 login tokens. | 2023-09-04 13:56:20.374
Symbol settings MD5 received. Request ID: 1. | 2023-09-04 13:56:21.518
Requested symbol settings for service code interactive_brokers.trading. Request ID: 2. | 2023-09-04 13:56:21.518
Requested user files to download. | 2023-09-04 13:56:22.733
User files to download complete | 2023-09-04 13:56:33.839
Symbol settings received. Request ID: 2. | 2023-09-04 13:56:33.876
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:56:34.024
IB TWS socket (1) | Creating socket. | 2023-09-04 13:56:34.024
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:56:34.024
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:56:34.024
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:56:36.048 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:56:36.049
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:56:36.049 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:56:36.049 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:56:36.049
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:56:36.049
IB TWS socket (1) | Closed. | 2023-09-04 13:56:36.049
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:56:36.076
Interactive Brokers | Disconnected. | 2023-09-04 13:56:36.076
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:56:36.076
Files to Open on Startup | File does not exist: C:\SierraChart\Data\ExampleChartbook.cht | 2023-09-04 13:56:37.244
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:56:38.078
IB TWS socket (1) | Creating socket. | 2023-09-04 13:56:38.078
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:56:38.078
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:56:38.078
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:56:40.119 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:56:40.119
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:56:40.119 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:56:40.119 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:56:40.119
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:56:40.119
IB TWS socket (1) | Closed. | 2023-09-04 13:56:40.120
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:56:40.135
Interactive Brokers | Disconnected. | 2023-09-04 13:56:40.135
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:56:40.135
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:56:42.136
IB TWS socket (1) | Creating socket. | 2023-09-04 13:56:42.136
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:56:42.136
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:56:42.137
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:56:44.153 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:56:44.154
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:56:44.154 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:56:44.154 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:56:44.154
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:56:44.154
IB TWS socket (1) | Closed. | 2023-09-04 13:56:44.154
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:56:44.175
Interactive Brokers | Disconnected. | 2023-09-04 13:56:44.175
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:56:44.175
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:56:46.171
IB TWS socket (1) | Creating socket. | 2023-09-04 13:56:46.171
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:56:46.171
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:56:46.171
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:56:48.188 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:56:48.188
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:56:48.188 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:56:48.188 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:56:48.188
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:56:48.188
IB TWS socket (1) | Closed. | 2023-09-04 13:56:48.188
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:56:48.203
Interactive Brokers | Disconnected. | 2023-09-04 13:56:48.203
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:56:48.204
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:56:50.205
IB TWS socket (1) | Creating socket. | 2023-09-04 13:56:50.205
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:56:50.205
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:56:50.205
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:56:52.235 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:56:52.235
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:56:52.235 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:56:52.235 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:56:52.235
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:56:52.235
IB TWS socket (1) | Closed. | 2023-09-04 13:56:52.235
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:56:52.253
Interactive Brokers | Disconnected. | 2023-09-04 13:56:52.253
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:56:52.253
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:56:54.252
IB TWS socket (1) | Creating socket. | 2023-09-04 13:56:54.252
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:56:54.253
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:56:54.253
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:56:56.298 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:56:56.298
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:56:56.298 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:56:56.298 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:56:56.298
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:56:56.298
IB TWS socket (1) | Closed. | 2023-09-04 13:56:56.298
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:56:56.313
Interactive Brokers | Disconnected. | 2023-09-04 13:56:56.314
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:56:56.314
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:56:58.315
IB TWS socket (1) | Creating socket. | 2023-09-04 13:56:58.315
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:56:58.315
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:56:58.315
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:57:00.329 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:57:00.329
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:57:00.329 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:57:00.329 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:57:00.329
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:00.329
IB TWS socket (1) | Closed. | 2023-09-04 13:57:00.330
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:57:00.345
Interactive Brokers | Disconnected. | 2023-09-04 13:57:00.345
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:00.345
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:57:02.354
IB TWS socket (1) | Creating socket. | 2023-09-04 13:57:02.354
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:57:02.354
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:57:02.354
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:57:04.369 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:57:04.371
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:57:04.371 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:57:04.371 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:57:04.371
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:04.371
IB TWS socket (1) | Closed. | 2023-09-04 13:57:04.371
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:57:04.384
Interactive Brokers | Disconnected. | 2023-09-04 13:57:04.384
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:04.385
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2023-09-04 13:57:06.231
The message log has been sent to support. | 2023-09-04 13:57:06.231 *
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | New receive buffer size: 0 | 2023-09-04 13:57:06.231
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 95.216.233.104. | 2023-09-04 13:57:06.231
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:57:06.385
IB TWS socket (2) | Creating socket. | 2023-09-04 13:57:06.386
IB TWS socket (2) | New receive buffer size: 0 | 2023-09-04 13:57:06.386
IB TWS socket (2) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:57:06.386
The Message Log was sent. Result: Message Log received. | 2023-09-04 13:57:06.435 *
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | CloseSocket call. | 2023-09-04 13:57:06.682
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2023-09-04 13:57:06.683
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2023-09-04 13:57:06.719
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2023-09-04 13:57:06.719
IB TWS socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:57:08.432 *
IB TWS socket (2) | CloseSocket call. | 2023-09-04 13:57:08.433
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:57:08.433 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:57:08.433 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:57:08.433
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:08.433
IB TWS socket (2) | Closed. | 2023-09-04 13:57:08.433
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:57:08.448
Interactive Brokers | Disconnected. | 2023-09-04 13:57:08.448
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:08.448
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:57:10.435
IB TWS socket (1) | Creating socket. | 2023-09-04 13:57:10.435
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:57:10.435
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:57:10.435
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:57:12.472 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:57:12.472
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:57:12.472 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:57:12.472 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:57:12.472
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:12.472
IB TWS socket (1) | Closed. | 2023-09-04 13:57:12.473
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:57:12.488
Interactive Brokers | Disconnected. | 2023-09-04 13:57:12.489
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:12.489
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:57:14.495
IB TWS socket (1) | Creating socket. | 2023-09-04 13:57:14.496
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:57:14.496
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:57:14.496
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:57:16.532 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:57:16.532
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:57:16.532 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:57:16.532 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:57:16.532
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:16.532
IB TWS socket (1) | Closed. | 2023-09-04 13:57:16.533
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:57:16.548
Interactive Brokers | Disconnected. | 2023-09-04 13:57:16.548
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:16.548
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:57:18.546
IB TWS socket (1) | Creating socket. | 2023-09-04 13:57:18.546
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:57:18.546
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:57:18.546
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:57:20.583 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:57:20.584
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:57:20.584 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:57:20.584 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:57:20.584
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:20.584
IB TWS socket (1) | Closed. | 2023-09-04 13:57:20.584
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:57:20.596
Interactive Brokers | Disconnected. | 2023-09-04 13:57:20.596
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:20.597
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:57:22.598
IB TWS socket (1) | Creating socket. | 2023-09-04 13:57:22.599
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:57:22.599
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:57:22.599
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:57:24.637 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:57:24.637
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:57:24.637 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:57:24.637 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:57:24.637
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:24.637
IB TWS socket (1) | Closed. | 2023-09-04 13:57:24.638
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:57:24.653
Interactive Brokers | Disconnected. | 2023-09-04 13:57:24.653
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:24.653
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:57:26.669
IB TWS socket (1) | Creating socket. | 2023-09-04 13:57:26.669
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:57:26.669
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:57:26.669
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:57:28.703 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:57:28.704
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:57:28.704 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:57:28.704 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:57:28.704
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:28.704
IB TWS socket (1) | Closed. | 2023-09-04 13:57:28.704
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:57:28.719
Interactive Brokers | Disconnected. | 2023-09-04 13:57:28.719
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:28.719
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:57:30.717
IB TWS socket (1) | Creating socket. | 2023-09-04 13:57:30.717
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:57:30.717
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:57:30.717
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:57:32.741 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:57:32.741
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:57:32.741 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:57:32.741 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:57:32.741
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:32.741
IB TWS socket (1) | Closed. | 2023-09-04 13:57:32.741
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:57:32.756
Interactive Brokers | Disconnected. | 2023-09-04 13:57:32.757
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:32.757
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:57:34.759
IB TWS socket (1) | Creating socket. | 2023-09-04 13:57:34.759
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:57:34.759
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:57:34.759
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:57:36.789 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:57:36.789
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:57:36.789 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:57:36.789 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:57:36.789
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:36.789
IB TWS socket (1) | Closed. | 2023-09-04 13:57:36.790
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:57:36.805
Interactive Brokers | Disconnected. | 2023-09-04 13:57:36.806
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:36.806
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:57:38.800
IB TWS socket (1) | Creating socket. | 2023-09-04 13:57:38.800
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:57:38.801
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:57:38.801
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:57:40.844 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:57:40.844
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:57:40.844 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:57:40.844 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:57:40.844
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:40.844
IB TWS socket (1) | Closed. | 2023-09-04 13:57:40.844
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:57:40.860
Interactive Brokers | Disconnected. | 2023-09-04 13:57:40.860
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:40.860
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:57:42.863
IB TWS socket (1) | Creating socket. | 2023-09-04 13:57:42.863
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:57:42.864
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:57:42.864
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:57:44.912 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:57:44.912
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:57:44.913 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:57:44.913 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:57:44.913
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:44.913
IB TWS socket (1) | Closed. | 2023-09-04 13:57:44.913
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:57:44.928
Interactive Brokers | Disconnected. | 2023-09-04 13:57:44.928
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:44.929
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:57:46.929
IB TWS socket (1) | Creating socket. | 2023-09-04 13:57:46.929
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:57:46.929
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:57:46.929
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:57:48.959 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:57:48.959
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:57:48.959 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:57:48.959 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:57:48.959
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:48.959
IB TWS socket (1) | Closed. | 2023-09-04 13:57:48.960
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:57:48.975
Interactive Brokers | Disconnected. | 2023-09-04 13:57:48.975
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:48.975
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:57:50.966
IB TWS socket (1) | Creating socket. | 2023-09-04 13:57:50.966
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:57:50.966
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:57:50.966
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:57:52.995 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:57:52.997
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:57:52.997 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:57:52.997 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:57:52.997
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:52.997
IB TWS socket (1) | Closed. | 2023-09-04 13:57:52.997
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:57:53.013
Interactive Brokers | Disconnected. | 2023-09-04 13:57:53.013
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:53.014
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:57:55.018
IB TWS socket (1) | Creating socket. | 2023-09-04 13:57:55.018
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:57:55.018
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:57:55.018
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:57:57.045 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:57:57.046
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:57:57.046 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:57:57.046 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:57:57.046
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:57.046
IB TWS socket (1) | Closed. | 2023-09-04 13:57:57.046
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:57:57.061
Interactive Brokers | Disconnected. | 2023-09-04 13:57:57.061
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:57:57.061
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:57:59.059
IB TWS socket (1) | Creating socket. | 2023-09-04 13:57:59.059
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:57:59.060
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:57:59.060
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:58:01.093 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:58:01.093
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:58:01.093 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:58:01.093 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:58:01.093
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:01.093
IB TWS socket (1) | Closed. | 2023-09-04 13:58:01.093
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:58:01.108
Interactive Brokers | Disconnected. | 2023-09-04 13:58:01.108
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:01.109
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:58:03.106
IB TWS socket (1) | Creating socket. | 2023-09-04 13:58:03.106
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:58:03.106
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:58:03.106
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:58:05.139 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:58:05.141
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:58:05.141 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:58:05.141 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:58:05.141
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:05.141
IB TWS socket (1) | Closed. | 2023-09-04 13:58:05.141
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:58:05.161
Interactive Brokers | Disconnected. | 2023-09-04 13:58:05.161
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:05.161
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:58:07.161
IB TWS socket (1) | Creating socket. | 2023-09-04 13:58:07.161
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:58:07.161
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:58:07.161
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:58:09.215 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:58:09.215
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:58:09.215 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:58:09.215 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:58:09.215
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:09.215
IB TWS socket (1) | Closed. | 2023-09-04 13:58:09.216
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:58:09.246
Interactive Brokers | Disconnected. | 2023-09-04 13:58:09.247
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:09.247
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:58:11.260
IB TWS socket (1) | Creating socket. | 2023-09-04 13:58:11.260
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:58:11.260
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:58:11.260
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:58:13.292 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:58:13.292
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:58:13.292 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:58:13.292 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:58:13.292
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:13.292
IB TWS socket (1) | Closed. | 2023-09-04 13:58:13.292
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:58:13.307
Interactive Brokers | Disconnected. | 2023-09-04 13:58:13.307
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:13.307
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:58:15.305
IB TWS socket (1) | Creating socket. | 2023-09-04 13:58:15.305
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:58:15.305
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:58:15.305
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:58:17.339 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:58:17.339
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:58:17.339 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:58:17.339 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:58:17.339
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:17.339
IB TWS socket (1) | Closed. | 2023-09-04 13:58:17.339
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:58:17.355
Interactive Brokers | Disconnected. | 2023-09-04 13:58:17.355
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:17.356
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:58:19.360
IB TWS socket (1) | Creating socket. | 2023-09-04 13:58:19.360
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:58:19.360
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:58:19.360
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:58:21.396 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:58:21.396
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:58:21.396 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:58:21.396 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:58:21.396
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:21.396
IB TWS socket (1) | Closed. | 2023-09-04 13:58:21.396
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:58:21.416
Interactive Brokers | Disconnected. | 2023-09-04 13:58:21.416
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:21.416
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:58:23.418
IB TWS socket (1) | Creating socket. | 2023-09-04 13:58:23.419
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:58:23.419
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:58:23.419
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:58:25.452 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:58:25.452
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:58:25.452 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:58:25.452 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:58:25.452
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:25.452
IB TWS socket (1) | Closed. | 2023-09-04 13:58:25.452
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:58:25.468
Interactive Brokers | Disconnected. | 2023-09-04 13:58:25.468
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:25.468
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:58:27.470
IB TWS socket (1) | Creating socket. | 2023-09-04 13:58:27.470
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:58:27.470
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:58:27.470
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:58:29.521 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:58:29.521
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:58:29.521 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:58:29.521 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:58:29.521
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:29.521
IB TWS socket (1) | Closed. | 2023-09-04 13:58:29.521
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:58:29.537
Interactive Brokers | Disconnected. | 2023-09-04 13:58:29.537
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:29.537
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:58:31.536
IB TWS socket (1) | Creating socket. | 2023-09-04 13:58:31.537
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:58:31.537
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:58:31.537
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:58:33.559 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:58:33.559
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:58:33.559 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:58:33.559 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:58:33.559
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:33.559
IB TWS socket (1) | Closed. | 2023-09-04 13:58:33.560
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:58:33.574
Interactive Brokers | Disconnected. | 2023-09-04 13:58:33.575
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:33.575
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:58:35.585
IB TWS socket (1) | Creating socket. | 2023-09-04 13:58:35.585
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:58:35.586
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:58:35.586
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:58:37.621 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:58:37.622
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:58:37.622 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:58:37.622 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:58:37.622
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:37.622
IB TWS socket (1) | Closed. | 2023-09-04 13:58:37.622
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:58:37.637
Interactive Brokers | Disconnected. | 2023-09-04 13:58:37.637
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:37.637
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:58:39.647
IB TWS socket (1) | Creating socket. | 2023-09-04 13:58:39.647
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:58:39.648
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:58:39.648
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:58:41.658 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:58:41.658
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:58:41.658 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:58:41.658 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:58:41.658
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:41.658
IB TWS socket (1) | Closed. | 2023-09-04 13:58:41.658
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:58:41.673
Interactive Brokers | Disconnected. | 2023-09-04 13:58:41.674
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:41.674
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:58:43.684
IB TWS socket (1) | Creating socket. | 2023-09-04 13:58:43.684
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:58:43.684
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:58:43.684
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:58:45.716 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:58:45.716
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:58:45.716 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:58:45.716 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:58:45.716
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:45.716
IB TWS socket (1) | Closed. | 2023-09-04 13:58:45.716
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:58:45.731
Interactive Brokers | Disconnected. | 2023-09-04 13:58:45.731
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:45.731
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:58:47.734
IB TWS socket (1) | Creating socket. | 2023-09-04 13:58:47.734
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:58:47.734
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:58:47.734
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:58:49.780 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:58:49.780
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:58:49.780 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:58:49.780 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:58:49.780
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:49.780
IB TWS socket (1) | Closed. | 2023-09-04 13:58:49.781
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:58:49.797
Interactive Brokers | Disconnected. | 2023-09-04 13:58:49.797
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:49.798
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:58:51.803
IB TWS socket (1) | Creating socket. | 2023-09-04 13:58:51.803
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:58:51.804
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:58:51.804
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:58:53.841 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:58:53.841
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:58:53.841 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:58:53.841 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:58:53.841
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:53.841
IB TWS socket (1) | Closed. | 2023-09-04 13:58:53.841
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:58:53.857
Interactive Brokers | Disconnected. | 2023-09-04 13:58:53.857
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:53.857
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:58:55.859
IB TWS socket (1) | Creating socket. | 2023-09-04 13:58:55.859
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:58:55.859
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:58:55.859
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:58:57.881 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:58:57.881
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:58:57.881 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:58:57.881 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:58:57.881
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:57.881
IB TWS socket (1) | Closed. | 2023-09-04 13:58:57.881
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:58:57.897
Interactive Brokers | Disconnected. | 2023-09-04 13:58:57.897
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:58:57.897
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:58:59.898
IB TWS socket (1) | Creating socket. | 2023-09-04 13:58:59.898
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:58:59.898
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:58:59.898
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:59:01.932 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:59:01.932
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:59:01.932 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:59:01.932 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:59:01.932
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:01.932
IB TWS socket (1) | Closed. | 2023-09-04 13:59:01.932
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:59:01.946
Interactive Brokers | Disconnected. | 2023-09-04 13:59:01.946
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:01.947
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:59:03.935
IB TWS socket (1) | Creating socket. | 2023-09-04 13:59:03.936
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:59:03.936
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:59:03.936
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:59:05.958 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:59:05.958
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:59:05.958 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:59:05.958 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:59:05.958
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:05.958
IB TWS socket (1) | Closed. | 2023-09-04 13:59:05.959
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:59:05.974
Interactive Brokers | Disconnected. | 2023-09-04 13:59:05.974
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:05.974
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:59:07.967
IB TWS socket (1) | Creating socket. | 2023-09-04 13:59:07.967
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:59:07.967
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:59:07.967
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:59:10.009 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:59:10.010
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:59:10.010 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:59:10.010 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:59:10.010
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:10.010
IB TWS socket (1) | Closed. | 2023-09-04 13:59:10.010
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:59:10.024
Interactive Brokers | Disconnected. | 2023-09-04 13:59:10.025
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:10.025
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:59:12.030
IB TWS socket (1) | Creating socket. | 2023-09-04 13:59:12.030
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:59:12.030
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:59:12.030
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:59:14.088 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:59:14.089
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:59:14.089 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:59:14.089 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:59:14.089
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:14.089
IB TWS socket (1) | Closed. | 2023-09-04 13:59:14.089
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:59:14.104
Interactive Brokers | Disconnected. | 2023-09-04 13:59:14.104
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:14.104
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:59:16.099
IB TWS socket (1) | Creating socket. | 2023-09-04 13:59:16.099
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:59:16.099
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:59:16.099
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:59:18.147 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:59:18.148
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:59:18.148 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:59:18.148 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:59:18.148
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:18.148
IB TWS socket (1) | Closed. | 2023-09-04 13:59:18.148
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:59:18.163
Interactive Brokers | Disconnected. | 2023-09-04 13:59:18.163
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:18.163
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:59:20.156
IB TWS socket (1) | Creating socket. | 2023-09-04 13:59:20.157
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:59:20.157
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:59:20.157
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:59:22.177 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:59:22.177
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:59:22.177 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:59:22.177 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:59:22.177
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:22.177
IB TWS socket (1) | Closed. | 2023-09-04 13:59:22.177
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:59:22.192
Interactive Brokers | Disconnected. | 2023-09-04 13:59:22.193
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:22.193
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:59:24.190
IB TWS socket (1) | Creating socket. | 2023-09-04 13:59:24.190
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:59:24.190
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:59:24.190
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:59:26.216 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:59:26.217
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:59:26.217 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:59:26.217 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:59:26.217
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:26.217
IB TWS socket (1) | Closed. | 2023-09-04 13:59:26.218
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:59:26.232
Interactive Brokers | Disconnected. | 2023-09-04 13:59:26.232
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:26.233
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:59:28.243
IB TWS socket (1) | Creating socket. | 2023-09-04 13:59:28.243
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:59:28.243
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:59:28.243
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:59:30.285 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:59:30.285
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:59:30.285 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:59:30.285 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:59:30.285
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:30.285
IB TWS socket (1) | Closed. | 2023-09-04 13:59:30.285
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:59:30.302
Interactive Brokers | Disconnected. | 2023-09-04 13:59:30.302
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:30.302
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:59:32.313
IB TWS socket (1) | Creating socket. | 2023-09-04 13:59:32.313
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:59:32.313
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:59:32.313
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:59:34.334 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:59:34.335
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:59:34.335 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:59:34.335 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:59:34.335
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:34.335
IB TWS socket (1) | Closed. | 2023-09-04 13:59:34.336
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:59:34.350
Interactive Brokers | Disconnected. | 2023-09-04 13:59:34.351
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:34.351
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:59:36.346
IB TWS socket (1) | Creating socket. | 2023-09-04 13:59:36.346
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:59:36.346
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:59:36.346
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:59:38.367 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:59:38.367
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:59:38.367 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:59:38.367 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:59:38.367
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:38.367
IB TWS socket (1) | Closed. | 2023-09-04 13:59:38.367
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:59:38.387
Interactive Brokers | Disconnected. | 2023-09-04 13:59:38.387
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:38.387
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:59:40.393
IB TWS socket (1) | Creating socket. | 2023-09-04 13:59:40.393
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:59:40.393
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:59:40.393
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:59:42.429 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:59:42.430
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:59:42.430 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:59:42.430 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:59:42.430
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:42.430
IB TWS socket (1) | Closed. | 2023-09-04 13:59:42.430
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:59:42.445
Interactive Brokers | Disconnected. | 2023-09-04 13:59:42.446
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:42.446
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:59:44.436
IB TWS socket (1) | Creating socket. | 2023-09-04 13:59:44.436
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:59:44.436
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:59:44.436
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:59:46.464 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:59:46.464
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:59:46.464 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:59:46.464 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:59:46.464
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:46.464
IB TWS socket (1) | Closed. | 2023-09-04 13:59:46.464
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:59:46.481
Interactive Brokers | Disconnected. | 2023-09-04 13:59:46.481
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:46.481
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:59:48.483
IB TWS socket (1) | Creating socket. | 2023-09-04 13:59:48.484
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:59:48.484
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:59:48.484
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:59:50.510 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:59:50.510
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:59:50.510 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:59:50.510 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:59:50.510
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:50.510
IB TWS socket (1) | Closed. | 2023-09-04 13:59:50.511
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:59:50.526
Interactive Brokers | Disconnected. | 2023-09-04 13:59:50.526
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:50.527
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 13:59:52.523
IB TWS socket (1) | Creating socket. | 2023-09-04 13:59:52.523
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 13:59:52.524
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 13:59:52.524
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 13:59:54.558 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 13:59:54.558
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 13:59:54.558 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 13:59:54.558 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 13:59:54.558
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:54.558
IB TWS socket (1) | Closed. | 2023-09-04 13:59:54.558
IB TWS socket (0) | CloseSocket call. | 2023-09-04 13:59:54.574
Interactive Brokers | Disconnected. | 2023-09-04 13:59:54.574
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 13:59:54.574
The message log has been sent to support. | 2023-09-04 14:01:50.970 *
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Creating socket. Using TLS 1.2. | 2023-09-04 14:01:50.970
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | New receive buffer size: 0 | 2023-09-04 14:01:50.970
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Connecting to IP: 95.216.233.104. | 2023-09-04 14:01:50.970
The Message Log was sent. Result: Message Log received. | 2023-09-04 14:01:51.249 *
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | CloseSocket call. | 2023-09-04 14:01:51.496
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Shutdown started. Waiting for graceful close. | 2023-09-04 14:01:51.496
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Socket gracefully closed by remote side. | 2023-09-04 14:01:51.535
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Closed. | 2023-09-04 14:01:51.535
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 14:01:54.576
IB TWS socket (1) | Creating socket. | 2023-09-04 14:01:54.576
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 14:01:54.576
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 14:01:54.576
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 14:01:56.618 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 14:01:56.619
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 14:01:56.619 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 14:01:56.619 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 14:01:56.619
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 14:01:56.619
IB TWS socket (1) | Closed. | 2023-09-04 14:01:56.619
IB TWS socket (0) | CloseSocket call. | 2023-09-04 14:01:56.644
Interactive Brokers | Disconnected. | 2023-09-04 14:01:56.644
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 14:01:56.644
The message log has been sent to support. | 2023-09-04 14:02:39.439 *
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (1) | Creating socket. Using TLS 1.2. | 2023-09-04 14:02:39.439
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (1) | New receive buffer size: 0 | 2023-09-04 14:02:39.439
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (1) | Connecting to IP: 95.216.233.104. | 2023-09-04 14:02:39.439
The Message Log was sent. Result: Message Log received. | 2023-09-04 14:02:39.721 *
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (1) | CloseSocket call. | 2023-09-04 14:02:39.963
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (1) | Shutdown started. Waiting for graceful close. | 2023-09-04 14:02:39.963
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (1) | Socket gracefully closed by remote side. | 2023-09-04 14:02:40.002
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (1) | Closed. | 2023-09-04 14:02:40.002
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 14:03:56.643
IB TWS socket (1) | Creating socket. | 2023-09-04 14:03:56.643
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 14:03:56.643
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 14:03:56.643
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 14:03:58.689 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 14:03:58.689
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 14:03:58.689 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 14:03:58.689 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 14:03:58.689
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 14:03:58.689
IB TWS socket (1) | Closed. | 2023-09-04 14:03:58.689
IB TWS socket (0) | CloseSocket call. | 2023-09-04 14:03:58.707
Interactive Brokers | Disconnected. | 2023-09-04 14:03:58.707
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 14:03:58.707
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-09-04 14:05:58.715
IB TWS socket (1) | Creating socket. | 2023-09-04 14:05:58.715
IB TWS socket (1) | New receive buffer size: 0 | 2023-09-04 14:05:58.715
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-09-04 14:05:58.715
IB TWS socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2023-09-04 14:06:00.753 *
IB TWS socket (1) | CloseSocket call. | 2023-09-04 14:06:00.754
Interactive Brokers | Failed to connect to the data and trade server. | 2023-09-04 14:06:00.754 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-09-04 14:06:00.754 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-04 14:06:00.754
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 14:06:00.754
IB TWS socket (1) | Closed. | 2023-09-04 14:06:00.754
IB TWS socket (0) | CloseSocket call. | 2023-09-04 14:06:00.769
Interactive Brokers | Disconnected. | 2023-09-04 14:06:00.769
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-04 14:06:00.769
[2023-09-04 19:56:05]
Sierra_Chart Engineering - Posts: 17190
Is Interactive Brokers TWS running on the same computer where Sierra Chart is installed?
[2023-09-05 13:12:24]
User101871 - Posts: 9
Yes it was running perfectly and suddenly stopped working.
now i pay for the sierra chart package and nothing works anymore!!!
[2023-09-19 23:02:57]
We apologize for the delay here. This had gotten overlooked. In TWS settings there is a way to add a trusted IP address. Make sure the localhost 127.0.0.1 is allowed.
Refer to step 9 here:
Interactive Brokers Trading Service: Setup Instructions
Date Time Of Last Edit: 2023-09-19 23:03:40
