Date/Time: Mon, 16 Sep 2024 19:23:23 +0000
Help with Volume Imbalance Please
View Count: 1111
[2014-07-14 03:19:10] |
Rino - Posts: 124 |
I have the Diagonal Dominant Side set to color white on the dominant side as shown in Numbers Bars. Can I also have it show a different color when it goes above say 300% along with the white? (As shown. I simulated it to show what I mean) Thanks https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=2958 |
Attachment Deleted. |
[2014-07-14 05:13:02] |
This is not entirely easy for us to answer because we are not totally clear as to all of your Numbers Bars settings. You need to set the Column 1 Compare Thresholds to the actual percentages that you require. We have updated the documentation in this section here to better explain how this works: https://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php#DiagonalComparison (Diagonal Comparison of Bid Volume and Ask Volume) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-14 07:16:32
