Date/Time: Mon, 25 Nov 2024 20:44:25 +0000
Allow input of seconds on opening range (or .5 minutes) 30 second opening range
View Count: 409
[2023-08-26 12:21:32] |
mrchet - Posts: 15 |
Hi, Im referring to the TPO settings ... "Highlight Opening Range on TPO profiles" "Opening Range Time Length in Minutes" setting. Maybe I'm missing a setting somewhere else. In the product I trade, the generally accepted opening range for a lot of strategies is 30 seconds. In the study settings 30 seconds (or 0.5 minutes) does not seem to be selectable. SC won't take that as input. Am im missing something. IS the a way to set that input to be either seconds (or allow a .5 minutes entry)? Thanks. |
[2023-08-26 21:28:42] |
Sierra_Chart Engineering - Posts: 17174 |
This would be difficult to implement with the way these charts work. Not impossible but it's not easy to do.
[2024-02-04 19:59:30] |
Christopher Lecusay - Posts: 6 |
I would love for that to be implemented. As the 30 second opening range is generally accepted.
