Date/Time: Wed, 27 Nov 2024 08:28:07 +0000
is there a way to automatically remove erroneous / shadow bars?
View Count: 263
[2023-08-26 11:29:59] |
User735389 - Posts: 189 |
erroneous bars being large spikes in the after hours that shoot one way, then return back to the original price a bit later. i understand there's a way to change it manually, but wondering if there's already a method to fix this automatically. see attached, for AI stock
[2023-08-27 18:45:13] |
Sierra_Chart Engineering - Posts: 17191 |
Update Sierra Chart to the latest version: Software Download: Fast Update Make sure this option is disabled: Data/Trade Service Settings: Process Known Odd Lot Equity Trades for DTC Services (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings) Re-download the data: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
