Date/Time: Mon, 16 Sep 2024 19:11:37 +0000
True range indicator
View Count: 1067
[2014-07-14 02:46:25] |
User17064 - Posts: 70 |
Hi SC support, Is there any true range indicator available?For example, list add the range of the bar in the bar chart. |
[2014-07-14 04:36:56] |
It is not completely clear what you are looking for. There is the Average True Range study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s19 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
