Date/Time: Wed, 27 Nov 2024 11:38:36 +0000
Teton
View Count: 370
[2023-08-25 17:39:01] |
Mike Todd Sr - Posts: 2 |
I belong to G7FX program and they told me to sign up using Sierra Chart - Denali - CGQ(No Data - Order Routing only) with Amp brokers. I noticed that Amp has a new option (Sierra Chart Teton) that their support said I should use. Could you tell me what would be better for me to use and would it save me money? |
[2023-08-25 17:52:13] |
John - SC Support - Posts: 36309 |
If you are only trading the CME Group, then we recommend using our Teton Order Routing Service. This is software that we built to do the order routing for Sierra Chart with the CME Group. Refer to the information at the following link: Sierra Chart Teton Futures Order Routing In terms of savings, the Teton Order Routing does not charge anything for the order routing. This typically costs $0.10 per side with other services, so this is where the cost savings come from. If you are are trading other exchanges, then you will need to use CQG for those other exchanges. Keep in mind that Sierra Chart does not have support for CQG data for the CME Group and EUREX, so even if you use CQG for your order routing, you would need to get the data for those exchanges from us. Additionally, you could use our Teton Order Routing for your CME Group trading and CQG for other exchanges. But it would require that you have two accounts with AMP. If this is something you are interested in, then you would need to have two installations of Sierra Chart to do this best - in which case refer to the following for how to install a second Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
