Date/Time: Wed, 27 Nov 2024 11:39:35 +0000
function to shut down daily activity
View Count: 223
[2023-08-25 15:52:09] |
User970210 - Posts: 84 |
Hi, Is it possible to only shut down long side or short side trading separately through a function? thx |
[2023-08-25 17:18:59] |
John - SC Support - Posts: 36309 |
There is not a built-in method to do this. You could create a custom study that would do it. Refer to the information starting here: Advanced Custom Study Interface and Language (ACSIL) Or you could hire someone to create a custom study for you. Refer to the list we have at the following link: List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
